ONCE I INSTALL A NEW DRUM IN A RICOH AFICIO 450 COPIER WHAT CODE TO I ENTER IN TO INITIALIZE THE UNIT?
  • 493 Answers
First please do not forget to remove the cap of the toner cartridge.
After Replacing the developer run sim. 2-801 in service mode.
Hope this helps.
Posted on Jun 01, 2010
Change drum
If copier is saying to replace it. Will need to by a photoconductor unit then open right side door then open front door pull toner assy out ward and on photo unit front bottom press on latch each side and pull it out to remove it. There might be instruction after putting new one in to run a initialize code
Jan 23, 2014 | Ricoh Aficio MP 1600 Black and White...
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
Error sc 350-1
ID sensor error
dirty id sensor-- pull out the drum unit and from the right door clean the id sensor (above the drum)with a dry cloth
Jan 07, 2010 | Ricoh Aficio 450 Copier
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
I have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Nov 10, 2008 | Ricoh Aficio 450 Copier
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
35 people viewed this question
k24674
jasbo
jasbo
