Question about Amana AMV1162 Microwave Oven
Microwave not heating,stopped suddenly.Everything else works.
Microwave quit heating,
Could this be a fuse problem?
Were are the fuses located?
Thanks
Cliff
  • Amana Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhj
Posted on Sep 30, 2010
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
My Microwave suddenly stopped working. Is there any set up or quickfix I can do. I am not seeing any visible problem as such but heat is not working. MH6110xbq-6 Thanks
Unplug it and take off the cover. If it has a ceramic fuse, it could have gone out. If so, replace it with the SAME model/type of fuse.
Oct 09, 2010 | Whirlpool Microwave Ovens
Our microwave all of sudden quit working. Had no
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1540 Microwave Oven
My microwave suddenly stopped heating anything, kenmore 721.62629200
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
If there is no noise at all the fuse may need to be replaced.
UNPLUG YOUR MICROWAVE BEFORE WORKING ON IT...
Read the owners manual to locate the fuse, remove it and take it to a parts supply store. Let the technicians test the fuse for you. If ti is bad, they can give you a new fuse to install. If it is not the fuse, they can recommend a reputable repairman to service your microwave.
Feb 05, 2010 | Microwave Ovens
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Microwaze suddenly stopped heating food, runs well but just does
take outer cover off look inline with the black wire
Aug 31, 2009 | Microwave Ovens
My oven started arching with micowave popcorn (4 or 5 different times). Now it will not heat. No error messages on the screen and everything else works. Thanks Dennis M.
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile spacemaker stopped heating all of a sudden everything else works. vent turning plate etc.Model # JVM1660CB Serial # F2909188S should I fix or buy new one...and which is the new model?
You may have a fuse that burned out. not everything runs on the same circuit . If its not the fuse than its probably the mega-tron, and that's big money. Check the fuse first. good luck DFD
Apr 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
Amana AMV1162 Microwave Oven Logo
222 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
foster_mommy
Level 1 Expert
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
