Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Dish washer not draining
I have a paykel and both draws are draining
  • 523 Answers
If neither are then its in the plumbing of the house
Posted on Jun 01, 2010
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Fisher and paykel dish draw not draining
If the problem is with both drawers, then most likely kitchen side drain is blocked. But if only one drawer, then need to clean filter and drain sump at base or if pump motor is not running then replace the pump rotor.
Mar 21, 2013 | Fisher and Paykel Dishwashers
My fisher&paykel 2 double dish washer works just fine no codes come up at but beeps from top one while running and even if it is not in use any time drawer is shut it beeps
If you find the dish wash makes the noise like the draw has been open and its mainly at night you most likely have cockaroaches. The dishdraws have infared sensors to tell it that the draw is open which works like a beam of light. When the beam of light is broken the draw thinks its open. When a cockie runs across the beam it blocks the light and the draw thinks its open. Get a good qulity surface spray and spray right around the door as they enjoy living near the warm CPU board. Most people don't realise they have cockies there untill i pull the draw cover off and show them.
Feb 09, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both draws are not drainng I thnk t my drain but not sur how get th dish waher out
if its both draws that arnt draining it is most probably going to be a blocked drain spiggot, its highly unlikley that both drain motors died at the same time, look under your sink where the drain hose attaches to the little drain spigot that comes off the pipe work (this is assuming that's how you have it setup as most people do) remove the drain hose and shove a screw driver down the spigot coming off your sink pipework to dislodge any gunk or seeds that may be stuck in there, also ensure the filters in the bottom of both draws are clean , hope this helps
Nov 05, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water in the bottom drawer
Take a glass and empty as much as possible. Take out the racks and get a towel to soak up the rest.
Take the washer arm out and detach the filter plate collar. Also take out the drain filter and clean everything. You could take the washer rotor out and clean the rotor cavity.
Put everything back and start the dishwasher on fast cycle. If water is still not draining and provided the pump is running, then you have a blockage in the drain hose or the kitchen sink end. If you are using inskerator then make sure it not blocked.
Jul 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Double dish draw
removed filter, removed rotor, check for obstructions in sump. If problem still exists physically check drain hose for restrictions/kinking
Jul 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer leaks
The f1 is a flood error. There is a sensor in the bottom reading water. You have to dry it out before you can do anything or the drain pump will just keep running. Check the lid of the drawer you where using to see if anything may have been holding it up or if the seal is torn. If that looks ok you will have to check the lid actuators to see if one is not working. I would replace both right and left if one is out.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
158 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
