Question about Kyocera Mita FS-1920 Laser Printer
Improving print speed
Duplexing mode print speed seems low after loading new driver for Windows7 64 bit. Is there a printer setting to fix this?
  • 4,924 Answers
No it is not..the printing speed is conditioned by the communication and the sheet ..font size..and such ...if it is appearing to be slower the fault is the communication ..but anyway look in the menu and see modes..some have a express mode for fast printing ..
Posted on Jun 01, 2010
Testimonial: "thank you. "
I have a Kyocera FS-1920 printer. I can't turn on the duplexing in the application on my computer. Do I need a specific driver to enable duplexing?
Assuming that your printer has the optional DU-61 duplexer installed you may need to check and make sure that the print driver knows the duplex unit is installed. Go to printer properties, device settings and check near the bottom of the list for installed options and make sure that the duplexer is checked off.
Jan 10, 2015 | Kyocera Office Equipment & Supplies
HP Photosmart B210a doesn't support manual duplex printing
Hi Marc,
Use the B110 print driver found at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=au&destPage=document&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0002&lc=en&product=4022343&.
It is terrible that HP can release a product with such a useless print driver.
Andrew
Dec 31, 2011 | Office Equipment & Supplies
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Can not print in duplex mode I can not print
Why don't you just print the data on the one side of the page and then simply turn the page over and reinsert it into the paper feeder and then print the next bit of data, therfore you end up with both sides of the page printed without worrying about printer commands that seem to fail.
Feb 12, 2011 | HP cp1700 Color Inkjet Printer
Duplexer not working with my new vista 64 bit system, can't find drivers...the standard vista drivers don't work.
You could load the 32bit version of XP in to a VM and share the printer.  You would then print via the VM.
Why are you using 64 bit Vista?
May 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Feb 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Duplexer
duplexing has to do with sending and receiving data at the same time. there is also half duplex mode: is where the device can send and receive but not at the same time. try going to start, control panel, printer faxes, find your printer , right click and enter printing prefrences.there may be a tab that says finishing. click this tab and make sure you checkmark print on both sides.
please let me know the outcome if that doesnt fix it i will check into that printer a little more. just another note vista is alittle quircky still so make sure the drivers are updated and vista is updated.
Feb 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
Kyocera Mita FS-1920 Laser Printer Logo
114 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
