Question about Hoover F5906-900 Upright Steam Vacuum
The brushes do not rotate. It is not the filter.
  • 438 Answers
Hi There,
When the brushes stop spinning, this indicates either that your spin scrub brushes are dirty and need cleaning, or that the internal turbine assembly has gone bad. Unfortunately this problem is widespread on Hoover SteamVac's.
No worries though, I have written a detailed diagnosing of this problem, and explain step by step how to fix it.
Please visit the link below:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
If you have any follow up questions, or would like further help, please just add your question to the comment or clarification request form here on Fixya, and I'll be more then happy to help.
Thanks,
Chris Jones
GoVacuum.com
Posted on Jun 01, 2010
Testimonial: "I believe your solution is right on the money. I appreciate the help. Now to order the part."
    President:
  • 3,085 Answers
3 Suggested Answers
SOURCE: brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
Posted on May 18, 2008
sawdust46694
  • 398 Answers
SOURCE: Brushes wont rotate
the belt has streached go to walmart and get a new one.
Posted on Aug 13, 2009
How do i fix the brush on my babyliss rotating hot air brush as it has stopped working after two goes..
you need to replace the drive belt look for screws on bottom and access plate left or right.
Jan 21, 2015 | Filter Vacuums
Why does the rotating brush not work ?
Check to make sure rotating brush is turned on and check for broken or worn belt
Sep 02, 2014 | Electrolux Vacuums
Rotating brushes don't spin.
Turn it over and pull out the brush holding assembly and insure that the master brush's stem is not broken off in the socket. The socket is geared to the vacum operated turbine that powers the brushes. There is the air input located next to the brushes and the filter might be clogged. If no air is being sucked into this red filter then it will have no vacum to turn the brushes. Insure that the flap is not closed behind the input filter. The flap is controlled by the brushes on selector switch.
Jan 29, 2011 | Hoover F5888-900 SteamVac Upright Wet/Dry...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes do not rotate when cleaning carpet. Is in carpet clean mode and will not rotate. I did clear the filter underneath.
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism
Oct 22, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Why did the brushes stop rotating?
Please check two things:
(1) The shutoff switch on the hood is NOT set to OFF for brush speed.
(2) Remove the red filter panel from under the cleaner, behind the brushes, and clean the hair/debris from the screen filter. Squeeze the two panels together, and pull down to remove from the pocket.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac model 7210-900
Did you clean both filters? There is one on the tank and the other is from the bottom, it ha a red frame, pull it out to clean. Pull the brush block out, is the shaft that goes up into the machine broken off? If so replace the brush block. While it is out, trn the machine on and see if the square hole up where the brush block goes, is turning. If not then the turbine has gone bad. You can sometimes clean the turbine out, otherwise replacing it may be the best option.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate
May 17, 2008 | Vacuums
Hoover F5906-900 Upright Steam Vacuum Logo
707 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
