Question about Kenmore 22422 Top Load Washer
My Kenmore topload washer won't start. I put a load of laundry in and it filled up, then completely stopped and won't drain or agitate or anything at all. I've checked the power source and that is not the problem. What else could it be?
    President:
  • 949 Answers
If you have power and will do nothing after filling the problem is most likely due to the lid switch.
The washer is designed to not allow the motor to run without the lid being closed, if the lid switch breaks, the machine thinks the lid is open and will not allow the motor to run.
If you want to make the repair yourself there are a couple good video clips that will show how to do this, I have put a link to them at the bottom of this note.
If you need help finding the part, you can get Kenmore parts from Sears. I can help you look up what you need if you can get me the complete model number from the tag that is visible with the lid open.
Lid Switch Videos
Posted on Jun 01, 2010
Washer will not stop filling up with water and won't agitate
Is the standpipe for the drainhose at least the height of the basket or control panel?
May 26, 2012 | GE Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series is NOT DRAINING or AGITATING
motor to transmission coupling or transmission itself.
Jul 02, 2009 | Kenmore 23822 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Load Washer 209049
Does your washer fill , but not agitate or spin? If this is the case, the fine graphite looking dust you are seeing is actually part of the rubber bushing to your motor coupling. The motor coupler is located between the transmission and drive motor under the wash tub. It is quite common for the coupler to go bad, especially if the machine gets used a lot. The part costs about $10 to purchase and is fairly simple to replace. Let me know if your symptoms match what I'm describing here.
Jul 02, 2007 | Kenmore 24872 Top Load Washer
Kenmore 22422 Top Load Washer Logo
22 people viewed this question
fordexpert
Mike Squire
Robert Rankin
