Question about Maytag MDE9700AYM Electric Dryer
F5 on neptune dryer
I have an upside down f with a 5 blinking code. power on but nothing happens. does anyone know what this means?
vest6
  • 196 Answers
SOURCE: maytag neptune dryer
This is an electrical problem associated with the control card. These cards are delicate and it does'nt take much too burn them out.
Another item associated with this is the door switch. If it is faulty then the control board will not allow the unit to start.
Posted on Jan 10, 2008
reg501
  • 413 Answers
SOURCE: Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
Posted on Jun 01, 2008
heatman101
  • 43501 Answers
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
jnchahn
  • 252 Answers
SOURCE: I have a maytag neptune
Try unplugging the dryer for fifteen minutes or so. If that doesn't do it then you have board problems.
Posted on Apr 30, 2011
Daniel S
  • 4323 Answers
SOURCE: Amana Gas dryer md#NGD7200TW error
Hi
The error should be "ts" from what you have described and this error means that the dryer thermister is either shorted or open. If you have already cleaned the lint filter then it is the thermister that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this part for continuity and if bad replace it, as it cannot be reset. If thermister is fine then test the thermostat, thermal fuse located near thermister for continuity. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 25, 2011
Upside down letter F and #5
does it look like this? t5 or ts could be a thermistor code.if you changed out the thermistor you most likely have a bad computer board.there should be a tech sheet in the machine usually in the top console. here's something that might help http://mikemerrittmotors.yuku.com/topic/2255 the machine doesn't run is that correct?i would check the obvious things,open the door and push in on the door switch and make sure that's working correctly,it should click when you push it in,there's a switch on the belt pulley,if the belt broke the dryer won't start,then check the thermal fuse,the thermistor and if they all check good then you have a bad computer board.just have to get in there with a meter and start reading out parts,also make sure you have 240 volts coming to the dryer,you can check it at the block where the cord connects to the dryer,after that unplug it and check all the other parts for continuity and you have to remove at least one wire off of the part you're checking.also here's the sears site so you can look up your parts if you don't have this site already. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE9700AYW/3048/0151200?pathTaken=&prst=0&shdMod=MDE9700AYW good luck and wish i could help you out more
Dec 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Does not turn on and run
CANT FIND CODE DRYER SHOWING UPSIDE DOWN F WITH #5
Jul 29, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9700AYM Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
