Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Water not entering into drum, but drum will spin in spim mode Last week water inter the drum but had to shut door hard a few times to start wash
  • Maytag Master
  • 12,061 Answers
Your door switch maybe faulty, http://www.servicematters.com/maytag_library/docs/16000416.pdf
There is your service and repair manual, use the troubleshooting steps to isolate and repair your issue. http://www.washerhelp.co.uk/diy-repair-help.html
Posted on Jun 01, 2010
Motor on wash cycle does not spim
??? wash cycle is not suppose to spin only agitate, most machine have a dual motor function, motor runs in 1 direction for wash then in another direction for spin. do u mean it does not go into spin? if so need to check the tranny and the clutch, the motor coupler in some cases and if its not agitating washing may have bad cam dogs in agitator, or bad water pressure switch, some times a bad door switch will not allow spin or agitation?
Sep 27, 2014 | Whirlpool Cabrio WTW6200VW 4.5 Cu. Ft. Top...
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
My washing machine starts and then goes off after
I'm not sure which model that you have, but I will venture to guess that it is a Maytag MAH5500BWW. If that is the model you have, I would say that your problem is with the motor/motor control panel, this has been re-engineered with a replacement. You can check all functions of your machine by placing it in service mode.To do this, turn machine on then press the delicates and heavy soil key for 3 seconds, then press spin to do a quick spin test. If it doesn't spin, then you may have that faulty motor design. In your machine behind the touchpanel on top there should be a tech sheet for your machine which tells you how to do this and how to check every operation of the machine. Replacing motor and control board is a very easy fix and if you contact Maytag (now whirlpool) they will give you a very nice price on all replacement parts for your machine. Hope its not the bearing!
Feb 07, 2010 | Maytag Neptune Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer will not spin
U might of dumped water on the motor which is really not good. it has a platic cover that helps protect it from splash over but its not designed for flooding really. will it still wash?
Mar 22, 2007 | Maytag PAV2300 Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
