Question about KitchenAid KERC507 Electric Kitchen Range
Oven door will not open self cleaning lock is stuck
    Genius:
  • 1,416 Answers
what this means is that your oven have develop some wiring problem from then voltage supply
it could also mean that then nouth and bouts which do the lucking function is weak
which will require a replacement
but the wiring you will have to open up the oven then trace the wire from the power supply to the door then check on the red wire if is well position
please put off all form of power supply when doing this work.
Thank you and thanks for using fixya.
Posted on Jun 01, 2010
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
F7 shows instead of door lock
This happens with a lot of ovens. It's because the mechanism that locks the door is stuck. When the door doesn't lock you can't do a self clean. They don't want you to be able to open the door while the oven is 800 degrees? or so. Look just below the little button that gets pushed in when the door is closed, upper left, and you should see a vertical slot. This is where a little lever comes out and grabs the slot on the door. There is a microswitch inside that tells the oven if the lever has come out or not. Your lever is stuck.
You can test this in a totally dangerous way by opening the door, holding in the button, and turning on the self cleaning. If everything is correct you will see the lever come out to grab and lock the door, but your's won't because it's stuck. Jiggle it or push on it or pull on it with needle nosed pliers. It frees up pretty easily. But when it does, the oven will go into self clean, which you don't want it to do with the door open, so turn it off, close the door and try again. It should work fine.
Dec 01, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Oven door lock is stuck locked. Using self cleaning function and now door won't open. Is there a trick to it.
If the oven is finished with the self cleaning cycle and cooled down, it should automatically unlock the door.If it doesn"t, try unplugging the oven to see if that will reset
Jan 09, 2011 | Ovens
I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Nov 14, 2009 | KitchenAid KGRS807S Gas Kitchen Range
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
F93 fault code
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
KitchenAid KERC507 Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
