Question about Hayward 2001 Series Millivolt Gas Pool Heater 200000 BTU ()
Pilot light gets blown out when heater ignites
When I start my heater, the pilot light gets blown out by the burners ignitingthere is a big woosh and alot of flame and then the heater will run until it reaches temp but then once it turns off i have to relight the pilot because it was blown out when the burners ignited. I have 3/4 inch gas line so supply is ok. I replaced the gas valve but it does the same thing. Had a service guy out who replaced the pilot generator and it did the same thing so that is not the problem. help!
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The jet(s) nearest the pilot assembly are clogged. Back them out of the manifold and clean out the spider nest or other debris. That should clear up the problem. And get a new service guy if they didn't take care of this when they were there!
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
Testimonial: "you are my hero. it was exactly what you said. I have been battling this for a year now and it took about 5 minutes to fix. You are correct that i need to find a new service guy even though that was the company the manufacturer suggested. Than you thank you"
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
My uniflame has two burners and one does not ignite. Everything seems to be tight. What can I do to get this to ignite when turning ignition knob? Thanks!
When you say two burners, I believe you are referring to the pilot flame and the main burner. The pilot flame has to light and heat the thermocouple befoe the main burner will ignite. The pilot flame will not light if: there is not enough gas in the tank, the pilot jet is clogged, or the regulator is bad. Check the tank to make sure it has gas. The next thing to check is the pilot jet. You have to take the heater apart, somewhat, to get to the pilot jet. The tube and the orifice need to be cleaned out, compressed air in a can and a pipe cleaner make the job a little easier. If this does not work, replace the reglator and hose.
Jul 22, 2011 | Uniflame GWT501A Open Flame Patio Heater
Startup cycle goes fine. All lights(power, pressure, thermostat, and heater) sequence correctly. After ignition, heater fires up(seen through viewing window) but then blows out 15 seconds later when fan...
If you are getting fire and have an eo5 this is a reading for no flame so it is not reading the flame. What you probally have is small spider webs in your burner orfaces. You will need to pull the burners out and with a small wire or the like clear the gas orfaces going to the burners. These little webs can divert the gas to the main burners and keep it from the burner that reads the flame. Your heater will come on with a big woosh as the gas needs to come from other burners to fire. I hope this helps. Good luck
Nov 24, 2009 | Pentair MINIMAX NT TSI IGNITER
Pilot light goes out when burners kick on burnham
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
Nov 07, 2009 | Goodman GMS90703BXA Heater
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
There are two at the beach and they won't stay lighted. The pilot kicks on, then you hear gas, then it ignites with a big swoosh and immediately goes out. This happens over and over.
Sounds like the pilot sensor is dirty if you can see where the pilot light burns the will be a metal rod that senses the heat of the pilot and tells the burner it can come on. clean the rod with steel wool. even a little build up can shut the burner down.
Aug 12, 2009 | DCS Large Appliances Outdoor Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Hayward 2001 Series Millivolt Gas Pool Heater 200000 BTU () Logo
147 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
