Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
I need a replacement USB wireless concetion module for my MK700
Module marked MK700, PID LZ933AV, P/N 820-002183
4 Suggested Answers
SOURCE: Broken Wireless Desktop Transmittter
I had this problem last year, after e-mailing logitech they sent me a replacement free of charge :). Although the replacement is not the same thumb drive style reciever (which they didn't have in stock), it is a desktop reciever, it works perfectly.
Posted on Jan 20, 2009
  • 118 Answers
SOURCE: my mini receiver is broken and my wireless combo
http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryid.11429200?WT.ac=sc|downloads||dd
Posted on Jul 17, 2009
SOURCE: my wireless keyboard and mouse just quit. have
Here are your drivers.
http://drivers.softpedia.com/get/KEYBOARD-and-MOUSE/LOGITECH/Logitech-Cordless-Desktop-EX-110-424.shtml
Have you checked/replaced the batteries?
Posted on Feb 09, 2010
Problem code c1440on 2003 ford explorer
C1440 Pressure Transducer Input Circuit Failure YES
C1440 (ABS only) Pressure Transducer Input Circuit Failure ABS Module Go To Pinpoint Test P .
Normal Operation The brake pressure switch provides an additional speed control deactivation if the brake pedal position (BPP) switch fails. When the brake pedal is pressed, 1700 kPa (246 psi) of brake fluid pressure in the brake master cylinder opens the brake pressure switch, removing B+ voltage to the speed control servo electric clutch.
    Possible Causes
  • circuit 10 (LG) open
  • circuit 307 (BK/YE) open, short to power
  • ABS module
  • brake pressure switch
  • speed control deactivator switch
PINPOINT TEST P: DTC C1440 (ABS ONLY) - PRESSURE TRANSDUCER SIGNAL FAULT CAUTION: Use the flex probe kit for all test connections to prevent damage to the wiring terminals. Do not use standard multimeter probes.
Test Step Result / Action to Take P1 VERIFY THE DTC
  • Connect the diagnostic tool.
  • Key in ON position.
  • Clear DTC C1440. Road test the vehicle. Repeat the self-test.
  • Does DTC C1440 repeat?
Yes
GO to P2 .
No
The system is OK at this time. P2 MONITOR THE BRAKE PRESSURE SWITCH PID FOR CLOSED POSITION
  • Enter the following diagnostic mode on the diagnostic tool: ABS Module PID.
  • Monitor the powertrain control module (PCM) brake pressure switch PID.
  • With foot off the brake pedal, does the PID read closed?
Yes
GO to P3 .
No
GO to P4 . P3 MONITOR THE BRAKE PRESSURE SWITCH PID FOR OPEN POSITION
  • Monitor the PCM brake pressure switch PID.
  • While pressing the brake pedal, does the PID read open?
Yes
GO to P9
No
GO to P7 . P4 CHECK THE CIRCUIT 10 (LG/RD) FOR AN OPEN
  • Key in OFF position.
  • Disconnect: Speed Control Deactivator Switch C1025.
  • Measure the voltage between the brake pressure switch C1025-2, circuit 10 (LG/RD), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to P5 .
No
REPAIR the circuit. CLEAR the DTCs and REPEAT the self-test. P5 CHECK THE BRAKE PRESSURE SWITCH
  • Measure the resistance across the brake pressure switch pins, component side.
  • Is the resistance less than 5 ohms?
Yes
GO to P6 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P6 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN
  • Connect: Speed Control Deactivator Switch C1025.
  • Disconnect: ABS Module C155.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE). harness side and ground.
Yes
GO to P9
No
REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test. P7 CHECK CIRCUIT 307 (BK/YE) FOR A SHORT TO POWER
  • Disconnect: Brake Pressure Switch C1025.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE), harness side and ground.
  • Is any voltage present?
Yes
No
GO to P8 . P8 CHECK BRAKE PRESSURE SWITCH
  • Start the engine.
  • Measure the resistance between the brake pressure switch C1025 pin 1, component side and the brake pressure switch C1025 pin 2, component side while firmly pressing the brake pedal.
  • Is the resistance greater than 10,000 ohms?
Yes
GO to P9 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P9 CHECK FOR CORRECT ABS MODULE OPERATION
  • Disconnect all ABS connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all ABS connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Jul 01, 2017 | Ford Cars & Trucks
Hi I have a 2006 Lincoln navigator the air suspension pump will not turn on the vehicle dynamics module is not turning on the pump relay because in the pid data the drivers door says it is ajar when it is...
Hey Jeff, any U- codes stored in any modules ?
U1900 Missing CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 . U2023 Invalid CAN message(s) Door(s) ajar, PRNDL, 4x4, instrument cluster (IC), running boards, vehicle speed REFER to Section 418-00 .
L4 CHECK THE VDM FOR DOOR AJAR INPUT
  • Monitor VDM door position status PID.
  • Close all doors, liftgate, liftgate glass and power running boards.
  • While observing the diagnostic tool, open and close one door.
  • Does the door status PID change between CLOSED and AJAR states?
When you open an close the driver door you have no PID change ,right ?
The door ajar input is an input to the Vehicle Security Module , then transmitted over the bus ! You'll have to find a diagram for the med. speed CAN data bus .
Jan 09, 2015 | 2006 Lincoln Navigator
My laptop will not finish loading it gets to this screen & stops - Wireless module not supported! The system detected a wireless module installed. The system is not supported. System halted! Please...
This is a fairly common problem with HP laps. Nobody, even HP, has come up with a definitive reason. Best thing to try:
>Replace the wireless NIC (network interface card) from your laptop. It will be accessed by removing a cover on the rear. This may or may not work.
OR
>Remove the NIC (described above). Get a USB wireless internet adapter. Install the drivers that come with it, then reboot the computer and plug it in to any USB port. Hopefully that should solve your problem.
HERE is a link to an adapter.
I carry one of these whenever I go out on calls in case the owner's computer has a failed NIC and can't access the internet and it never fails for me.
>Remove the wireless NIC
Oct 06, 2013 | HP 2000412NR AMD Dual-Core E300 Processor...
I have a hp g71 laptop and it keeps shutting down and says module 701 not found it also started making like a crackle sound then shuts off please help me
Error message - Module 701 error - means there is a problem with the Wireless card. Correct speak? Wireless Module
We need to diagnose, Christine
I would like to first suggest, to remove the Wireless Module, and see if the laptop works again.
There will probably be another error message, that there is a problem with wireless.
However one step at a time.........
Wireless Module removed, and laptop works, of course we now know the problem is just the Wireless Module, and not further into the computer.
1) Remove ALL power. Remove the AC adapter, (Charger)
FIRST, unplug the AC adapter from the surge protector, then unplug the AC adapter from the laptop.
(This method avoids a possible voltage spike)
Next remove the Battery.
Now press the Power On button, and hold down for a count of 10 seconds. (Relieves all residual power)
2) Suggest lay a soft static free cloth on a table, and the laptop laid upside down on it. Bottom side up, and Battery Compartment AWAY from you.
3) Remove the Wireless Compartment Cover,
http://www.ebay.com/itm/HP-G71-340US-Bottom-Housing-cover-A-Condition-370P7BATPG0-/261211061790?pt=US_Laptop_Housings_Touchpads&hash=item3cd1647e1e
This is the Base Enclosure, or also can be stated as the Bottom Cover; for sale. Using it for reference.
The Main view automatically shows as the Inside view.
Below the Main view there are two smaller views. Click on the view to the Right. Then put your mouse cursor on the main view.
Here in the Bottom view of the Bottom Cover, you can see the Battery Compartment at the Top. (And naturally, battery removed)
Immediately below it is a small rectangular open area, to the Battery Compartment's left side.
This is the Wireless Module Compartment.
One Philips head screw to remove. (No.1 Philips screwdriver, or equivalent Jewelers screwdriver)
Lift the cover up on the screw side.
This is what the Wireless Module looks like by itself,
http://www.ebay.com/itm/HP-G50-G60-G70-G71-CQ61-HDX-X16T-Laptop-Wireless-N-Card-/400116846704?pt=US_Internal_Network_Cards&hash=item5d28d29070
Looking at the Left side of the Wireless Module, note there are two small rounded terminals.
These are marked by the numbers 1 and 2.
When you remove the Wireless Module Compartment Cover, note that there are two wires attached to the module.
If memory serves one wire is Black, the other one White.
Make a note, and/or small drawing as to which of these wires go to the No.1 round terminal, and the No.2 round terminal.
They must be attached correctly later.
The rounded terminals on the Wireless Module, marked as No.1 and No.2; are essentially little cylindrical posts, and have a round flat top on them.
The Wireless Antenna wires connecting clips, are a flat spade terminal type of affair, with curved over edges; and have a flat spring underneath attached.
To remove the clips, gently push down on the clip, then slide back.
(Back towards the wire in the clip)
The wires are Wireless Antenna wires.
They thread up through a cavity hole in the body of the laptop, and go up by the Right Hinge, then up into the Display Assembly.
The Display Assembly has a Wireless Antenna that they connect to. There is NO power coming from the Wireless Antenna wires.
The power TO them, comes from the Wireless Module.
The Wireless Module receives power from the slot on the laptop, that it is plugged into.
I do not believe that if the Wireless Antenna wires were left to just dangle, that either one of them could contact, the contact pins in the interface slot of the laptop.
Then again, I do NOT want to take any chances with your laptop.
Suggest wrap a small piece of black plastic electrical tape, on each terminal for the Wireless Antenna wires.
(About as long as your thumbnail will do. Just wrap it over the wire's terminal, like a folded sheet of paper)
There is one Philips head screw, in the corner of the Wireless Module to remove.
Then the Wireless Module is slid back, and removed.
(DO NOT lift straight up at first!
Slide back, until the gold plated contact pins of the Wireless Module, are free from the interface on the laptop that it plugs into.
Then lift up, and out )
Suggest replace the Wireless Module cover, and turn the laptop on.
Laptop works, but indicates no wireless connectivity, you know you just need to replace the Wireless Module.
Laptop does not power up, of course there is a further problem.
This would suggest to me that the laptop is dirty inside, and needs to be cleaned.
Would also suggest if this does not 'cure' the problem, that the Thermal Paste on top of the Processor, needs to be PROPERLY replaced.
I can guide you step by step with either, or both endeavors.
[You will need though,
A) A can of compressed air for computers.
B) A soft small brush (Makeup brush?)
C) Tweezers
D) No.1 Philips screwdriver, or equivalent Jewelers screwdriver.
Thermal Paste needs replacing;
E) A small tube of Thermal Paste
F) A small piece, (1-1/2 inches by 1-1/2 inches. Is cut from a larger piece you buy, ) of Thermal Pad.
(A Thermal Pad is a material that is impregnated with Thermal Paste. It will be used on the graphics chipset)
G) The Large Hadron Collider
NO!............you gonna' believe that last oNe?..........geez!
H) An ESD wrist strap. Average price is around $3 to $6.
Connect it's alligator clip to a good ground source.
I) Believe in yourself. I believe in you.
I have taught two 9 year old children to perform this (In person), and countless people on here.
(It isn't countless, of course. I am just too lazy, to go through the more than 10,000 solutions I have given, to go see.........lol!)
As far as I know......................
Fixya has undergone a site change recently. You know, new 'paint', and 'drapes'. (This I DO know)
Since undergoing this change, I haven't received any response back; from the asker of the problem/s.
No response given by Comment.
Or by Reply at the end of the solution.
('Twilight Zone'.............do-dee-do-do, do-dee-do-do)
Which means to me I may not hear back from you, and be able to guide you further, or answer further questions.
In lieu of this I tried to post all possible solutions to your problem.
However, I may not be able to guide you with cleaning, or possible replacement of the Thermal Paste/Thermal Pad.
If this turns out to be the case, and you need the above information; would implore you to post as a separate problem.
A) Video of completely disassembling an HP G71 laptop;
Part 1:
(Remove WLAN Module starts at 0:23
Wireless Local Area Network Module.
Wireless Module for short)
http://www.youtube.com/watch?v=QEwsUB8fjQQ
Part 2:
Part 1 and 2 of course, to clean laptop, and replace Thermal Paste.
http://www.youtube.com/watch?v=NfechCFqC14
Just in case someday you need to replace the LCD screen;
http://www.youtube.com/watch?v=yIV54EdGxyM
(The Screw Covers are held on by a type of rubber cement.
You just carefully pry them off.
I -> Lightly <- stick them to the Display Bezel, for safekeeping.
This is the thin plastic frame in front of the LCD screen.
Regards,
joecoolvette
May 11, 2013 | Computers & Internet
Is there a wireless and bluetooth combination module
ever thing to ask HP real>? below?
we are not HP we sell nothing here nor are there drivers here,
or anything here, only chat.
the answer is sure, some PC sold by HP, and for sure laptops
have dual/ wifi/blue tooth miniPCI module offered day 1 new.
i just upgraded my neighbors for free.
This only applies to specific models, so ask HP.
answer 2 is buy a usb thingy,, blue tooth mines like f1/2 a finger nail long and fits on any pc made with USB jacks.. blue tooth add ons
are super best way to add it. and way cheaper too.
mine is 1/2 a dime sized. (not counting usb end that hides inserted)
real
https://h30434.www3.hp.com/
Jul 18, 2017 | HP Computers & Internet
Toshiba M55-S135:How to replace the internal mini pci wireless card? Which screws to remove?
Whoa!
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Put all of those screws back in. Tighten, but Do Not over-tighten.
3) http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M55/laptop_motherboard_1.htm
Scroll down, click on the photo for Step 2.
Remove the screw for the Wireless Module Cover. (Wireless card)
Lift the cover up ON the screw side.
There are tabs on the other side. (Side facing you)
Close the small window. Now click on the photo in Step 3.
White cable (Wire), and Black cable. Make a small mark on the White wire, (Sharpie?), and near the terminal on the Wireless Module Card the white wire goes to.
Remove the screw/s, remove the Wireless Module Card.
Reinstall in reverse.
Regards,
joecoolvette
Aug 15, 2012 | Toshiba Satellite M55-S135 Notebook
Airbag error 16
Flash code 16 can have several different possible causes.
It is for the Occupant Classification Sensor (OCS) system, as well as the passenger seat belt tension sensor..
Possible causes"
> OCS module internal fault
> OCS module calibration fault
> OCS module sensing element fault
> OCS module communications fault
> Front passenger belt tension sensor circuit fault
You need to pull Process Identifier (PID) codes to know which area to took for the fault.
Flash code 16 can be broken down into a smaller area of possibility with the PID code "B2290" and the symptom code (xx) following.
> B2290(24)
> B2290(25)
> B2290(26)
> B2290(27)
> B2290(29)
> B2290(31)
Getting a flash code 16 can also be a combination of faults that will show up as combinations of PID codes.
May 29, 2012 | 2002 Jaguar X-Type
Can't set up the buzzers for the buzz quiz world game.
Have you plugged in the USB wireless module and paired the buzzers to the ps3?
There is also a wireless usb module you need to plug into the ps3 usb ports should come in the buzzer packages.
Switch all the buzzers off
  1. Hold the power button on each buzzer for several seconds until the LED is lit on each
  2. With the USB wireless module plugged into your PS3, press and hold the bind button on the side of the USB module until the LED on each buzzer goes out.
Feb 28, 2011 | Sony Buzz Quiz World for PlayStation 3
Need replacement transmitter/ receiver , the one that fit in USB port mk700
Found replacement transmitter at Logitech store online. $10 + shipping as of 5/2013 . Here's the link.
http://buy.logitech.com/store/logib2c/en_US/DisplayCategoryProductListPage/categoryid.13930900?resid=UZ0P-goBAlkAACxWrvYAAAAG&rests=1369248224224
Feb 27, 2011 | Logitech Cordless Desktop EX110
My buzzers are not connecting
Feb 24, 2011 | Sony Buzz Quiz World for PlayStation 3
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
1,029 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
