Error code e4 on caple washing machine - Washing Machines
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: the washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Posted on Dec 19, 2008
SOURCE: i have a stirling washing machine xqb90-701clps
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Posted on Sep 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: f02
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
  • 170 Answers
SOURCE: The washing machine wont stop
If that is a whirlpool as you do not have a brand or mod # that would most likely be a flow sensor. It is located under the top cover. remove screws top rear remove cover on top of machine. you will see that device in the tubing located just after the water inlet valve it will be white round device and most likely will have to small blue wires going to it.That is a somewhat pricey little part like 100.00 last time I got one but with whirlpool who knows could be more or less now. On that note might be cheaper to have the unit looked at by a pro. If you remove the lower kick panal you should find the tech sheet that will tell you what the code means but I'am sure it is overflow .. If you need more help please ask....Thanks for voting good luck
Posted on Mar 16, 2011
Error code e4 frigidaire front load washing machine
Hello Minfaz, thank you for your post!
Based off what you have described your Frigidaire washer is displaying an error code of "E4". I am showing that this is an invalid error code. This might be a miscommunication within the control panel. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for roughly ten minutes. If your washer continues to display that error code please provide me with the model number. You can locate that information on the door frame of the washer on a silver or white tag. With that information I can research your washer further. -Matt
Jan 14, 2016 | Frigidaire Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
Samsung trouble shooting
The E4 is an error code. What the washing machine "is trying to communicate" to you is that it has detected a load imbalance at the clothes being washed; thus it won't be able to spin at full speed. Maybe it stops waiting for you to distribute the clothes more evenly. See more about error codes at http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html.
Aug 28, 2014 | Washing Machines
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
I have a GE Profile top loading washer mdl # WPGT9150 and I have a question about a problem I am having with it. The washer stops halfway through the wash cycle and the electronic board flashes E4, and I...
E4 is an error code indicating a problem with the water inlet valve or the electronics that control the inlet valve. Error codes do not necessarily indicate the problem directly.
Here is the service manual (with diagnostic procedures) for your machine:
http://www.geservicenet.com/cc/trngprog/ProfileWasherWPGT9150.pdf
Good luck.
Mar 01, 2011 | GE Washing Machines
I have a stirling washing machine xqb90-701clps and the machine has come up with an E4 error code.. cannot find my manual. what does that code mean?
Jul 25, 2010 | Washing Machines
The washeer machine give a error code E4
Dec 19, 2008 | Washing Machines
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
