Question about Whirlpool LGV4634JQ Gas Dryer
Dryer runs, no Heat
I replaced the igniter as it was not glowing when stated. Still nothing.
Could it be thermal fuse? Gas sensor? I do not want to start replacing everything as the dryer is 8 years old.
  • Jerrywrench May 24, 2008
    Model # LGR7646JQ Whirlpool Gas Dryer.
    Replaced both coils on gas valve, gas lights on start stays on low heat? Will not go to high heat? Will not relite. Ignitor gets hot than goes out? No gas , i do not hear the coils in gage? I did chane the Thermal Sensor first
  • Anonymous Jun 20, 2008
    applied 120volts to holding coil it picked up how do i check coil #2 does heat sensor sends voltage to coil # 2 which in turn open gas inlet valve
    President:
  • Whirlpool Master
  • 2,651 Answers
The ignitor is glowing??? and still no ignition?? if thats the case the thermostats are good, i would focus on the coils located on top of the vavle 279834, about 20 bucks. obvioulsy first check you do inded have gas coming into the unit
Posted on Apr 09, 2008
I just fixed my dryer, thus saving my marriage! It was definitely the gas valve coils. A couple of pointers I learned along the way: 1. Most dryer panels, once removed, have VERY sharp edges. Most of my cuts (4, the last time I counted) will heal within a few days.
2. The coils are located in the FRONT of the dryer. If you remove the rear panel, as I did, you can also clean an amazing amount of lint and toothpicks and bobby pins and whatever..
3. When the job is all finished, and you think you've solved the problem, and the dryer still does not heat - do not forget (as I did for a short time) to turn the gas back ON. It really helps!
Teddy
Posted on Aug 20, 2008
SOURCE:
My whirlpool duet dryer has no heat but turns on and spins with cold air. I cleaned vent and removed toe plate. If it is thermal fuse problem will the igniter glow still? I found a penny lodged on the fuse...
see this causes and fix it. I am supposing the dryer is gas because you are telling the igniter?
God bless you
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 28, 2012 | Dryers
Kenmore gas dryer 70932, 70942, 70952 won't heat. Dryer turns on and tumbles but won't heat.
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Oct 04, 2009 | Kenmore Dryers
My dryer runs but does not heat Kenmore 110.74722400
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 05, 2009 | Kenmore Dryers
Gas dryer does not heat up. Gas is on and the
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 01, 2009 | Dryers
Dryer runs, but does not heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 17, 2009 | Roper RGX4634KQ Gas Dryer
Turns on but wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 13, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer burner just stopped working. the motor turns but no heat. It also will not start on timed heat.
HI, i recommend inspecting all areas stated below to address this issue. the most common problem will be a set of defective gas valve coils but, i suggest checking all points before replacing the coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore Gas Dryer runs no heat were do I Start first
Check the following to address your issue. check each section of the dryer thoroughly.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 15, 2009 | Kenmore 74602 Gas Dryer
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
NOT HEATING
Ok, you did not state if this dryer is electric or gas so, i will post both solutions for each dryer type.
ELECTRIC--CHECK THE FOLLOWING
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
GAS--CHECK THE FOLLOWING
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Whirlpool Dryers
Whirlpool LGV4634JQ Gas Dryer Logo
206 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
