A VHS tape is stuck in my TV/VHS combo unit.
I have a Symphonic TV Model # 55C6099. A VHS tape is stuck in the VHS slot. It will not eject. I turn the TV on and it automatically turns off in about 10 seconds. How can I get the VHS tape out.
Thanks. Don S.
  • Shahid Electronics
    Shahid Electronics Jun 30, 2010
    Rylee, please!!!!!!!!! .. VCR does not have manual eject hole at all in any model of any brand. Stop posting BS info to get few bucks.
  • thdon1 Jul 13, 2010
    Well guys although I could not find a manual eject hole the information provided about a warp or dirt in the VHS tape helped me solve the problem and the TV and VHS are working well.
    I loosened/removed some of the casing around the tape creating some space and then was able to dislodge the tape. As suggested the tape was old, dirty and probably stepped on by all 17 grandchildren at sometime or other.
    My solution was not something found in a manual but desperation won!
    Don S.
  • 4,234 Answers
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Posted on Jun 04, 2010
Testimonial: "This helped also. Don S"
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that there is a manual Eject button which is usually a small hole located underneath the VHS drawer. Now insert a stiff wire—such as a paperclip or safety pin—into the hole and push gently and the drawer should open partway. Gently pull the drawer the rest of the way open. Remove the VHS and see if there is a problem with it. Most VHS player drawers get stuck when a VHS tape is wrapping or the label is starting to peel. If the VHS is warped, discard it. If the label is peeling, remove the label. If still the issue is not resolved, then take a smallest screw driver and press the eject button and put the screw driver in the cavity above the VHS drawer and it will be open and check that the VHS is not wrapped and looking fine. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
  • thdon1 Jun 01, 2010
    Rylee Smith - Thanks but I don't think I explained the problem correctly. There were some electronics between the base of the TV and the VHS slot. there was not any manual eject button. However, I did take part of the TV housing loose and when I put it back together the TV was working. Blind luck! My guess is the VHS was warped and I have thrown it out. I have not tried another VHS tape and am not sure when I will. Thanks for the help.
    Don S.
  • Rylee Smith
    Rylee Smith Jun 01, 2010
    Thanks for your reply Don, please post back if you require more assistance else you can rate the solution.
    Thanks
    Rylee
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic vhs tv turns off i hear the vcr after that it turns off
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Mar 16, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
VHS problem, any help?
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Televison & Video Logo
790 people viewed this question
Top Televison & Video Experts
Electro Med Services...
