Question about Kenwood KDC -X815
Kenwood excelon kdc-x815 display screen no power
I have a kenwood excelon kdc-x815 deck that i have replaced the ribbon on and everything works fine except the display screen does not light up... radio plays, but the station frequency doesn't display... i had the ribbon tested for connections and it is fine, i replaced the faceplate and still the same problem... so that leaves me with the unit?? any ideas on what would cause everything to work except the display screen?
    President:
  • 720 Answers
If you can turn the unit ON/OFF or operate the station presets on your faceplate, then the faceplate is OK.
It's possible the fault lies in the display resistors, inside the unit itself.
Check out my tutorial, which may help explain:
http://www.fixya.com/support/r16293427-repair_no_display_kenwood_faceplate
Cheers,
Scott
Posted on Feb 01, 2013
Recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Posted on Sep 04, 2010
Cannot get it to power on How does it work?
Kenwood Excelon DDX9902S DVD receiver at Crutchfield ...
www.crutchfield.com > ... > In-dash Video Receivers Crutchfield Corporation
Rating: 4 - ‎21 reviews - ‎$674.99 - ‎In stock
Kenwood Excelon DDX9902S Android Auto integrates your phone's app with the ....deliver an ultra-clean signal for adding additional amps for even more power. ...... Only thing I can't get to work with the Apple Car Play is the ITunes radio.
Car Stereos FAQ - Crutchfield
www.crutchfield.com > ... > Car Stereos
Crutchfield CorporationJump to What's the best way to connect the Crutchfield wiring ... - A: Most CDreceivers will play at least ... for example, some receivers work with ... If you can'tfind a new cassette deck ... the remote wire did not power the amp .... KenwoodExcelon KDC-X399 ... 12 tips for getting the best sound quality in your car.
Kenwood KDC-BT362U CD receiver at Crutchfield.com
www.crutchfield.com > ... > All Car Stereos
Rating: 4.5 - ‎174 reviews
A smartphone haven With Kenwood's KDC-BT362U CD receiver, you can ... A newcar stereo offers power that's superior to most factory radios, along with .... Gettingthe installation kit and the wiring harness with my stereo purchase was great. .... Cons: Pandora did not work and I tried contacting customer service and their ...
Kenwood - Car-Audio FAQ
Jan 06, 2016 | Kenwood Car Audio & Video
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or...
you may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Jul 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
When i turn the car on the control panel on the Kenwood excelon KDC-X769 jus starts on opening and closing but never stays opens
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Jun 20, 2010 | Kenwood eXcelon KDC-X769 CD Player
Faceplate doesn't work
you probably have bad solder connections on some of the surface mount resistors inside the deck.
Feb 10, 2010 | Kenwood Excelon KDC-X790 CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Sep 09, 2007 | Kenwood eXcelon KDC-X689
KDC-MP919 No display
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
Shutting Off
the usual repair for a morotized face plate with symptions of no display, some buttons working or no buttons working & sometimes even the faceplay not moving, is the ribbon backthat connects the main unit to the face plate. Sometime you might be able to see the gold/yellow flat ribbon as the face plate flips. it's not too difficult to cange but it takes patience. the cables run around $15 to $30.00.if you replace it yourself, watch out incase the spring for the ribbon tension unwinds. good luck
Dec 14, 2006 | Kenwood eXcelon KDC-X679 CD Player
Kenwood KDC -X815 Logo
656 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
