Question about Nikon D5000 Digital Camera
Nikkon 18-50 mm VR lens is not do the auto focus
I dropped my D5000 camera when I try to take a photo and it seems that the auto focus of the lens is not working any more. What should I do
  • 3 Answers
Try to reset it by switching on the camera, pressing and holding 'INFO' button near the trigger and 'I' button in the left-hand side bottom. Hold the buttons together for few seconds till information on LCD screen appears. I hope your autofocus will work after this.
If it doesn't, carry your camera to the service personnel.
Posted on Aug 19, 2010
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Oct 05, 2014 | Nikon D5000 Digital Camera
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
My 18-55 VR NIKKON lense on VR MODE changes focus area after each shot on same object on even tripod. why ?
Have you set your camera to the correct auto-focus mode; AF-A, AF-S or AF-C?
Feb 07, 2012 | Nikon Cameras
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
Nikon VR lens 18-55mm do not focus on auto
Is the lens aperture ring set to the "a" position?
Feb 16, 2010 | Nikon D5000 Digital Camera
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Nikon D5000 Digital Camera Logo
285 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
