Question about Whirlpool Dishwashers
Model GU1200XTKQ0..Water is not coming out of the upper washer arm. As a result the dishes on the upper rack are not getting clean...Possible fix?
    President:
  • 949 Answers
It sounds like you have lost pump pressure, with this loss it does not have enough to reach the upper area to clean properly. This is common for you model.
The easiest thing to check is the water level. Start a cycle (with or without dishes) and wait 2 minutes, carefully open the door and observe where the water level is, it should be slightly below the heat element in the bottom of the tub. If this is okay then we will look at the pump. If you started the cycle empty you can push the cancel drain button now.
The most common reason for low pressure for you model is debris in the sump area where the water enters the pump. Food and other debris can plug this intake and cause low pressure. Also below this intake is the chopper and screen, if they become blocked or the chopper breaks the same effect will take place. I have put together some details on how to get to the intake and chopper to clean. Follow the link below and let me know what you find.
Sump Clean out
Posted on Jun 01, 2010
  • lroth1615 Jun 01, 2010
    I was able to follow all of the steps. However I could not get the cover off to expose the chopper and the screen. I did not want to pry it off. Any suggestions?
  • Philip Jun 01, 2010
    Once the screw is out for the cover it will lift up from the left side, you might be able to get a needle nose pliers on the rim around where the screw was. This will get you a place to grab onto to lift, if you can't get something on there, you can put a small flat blade screwdriver on the left side of that cover and pry up, it should pop loose.
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Motor runs but
Do you have a print manual for this unit?
Aug 05, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
32 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
