My graphics controller, master ide controller and my audio controller are all out of date and i do not know wot to do now to fix them
  • 4 Answers
Find updates ;)
Posted on Jun 02, 2010
Pins location master slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps
Nov 24, 2012 | Gateway Motherboard Gt5408 Gt5438 Gm5407e...
When I download a program an click to install it a box pops up saying the download I am trying to install is not a valid Win32 application. This is a new problem. I have not had any problems downloading in...
This error message could be caused by a number of things. Generally it's because the program being downloaded is corrupt or didn't download completely. Have you tried a different browser to do the downloads? If it's a very large download you may encounter problems with losing packets. A download manager may help.
http://www.techspot.com/downloads/231-free-download-manager.html
Also, you may want to try doing a restore to system restore point to a date when you weren't having this issue. System Checkpoint dates (in bold) are usually very safe points to restore to. I would also recommend a virus scan and if you don't have this utility and are able to download and install it (yes I know that's your current problem, but you can download it to a flashdrive from a friend's comp and install it), I'd get Glarysoft Utilities and run the one-click maintenance which will fix any registry errors. It's free and is a great way to keep your machine running well.
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html
If any of this helps correct your problem I would appreciate a rating. People here seem to take the help and don't show any appreciation by taking the time to rate the help.
Jan 11, 2011 | Computers & Internet
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
I loaded a new, formatted IDE hard drive into an
If IDE drives are hooked to the same controller one must be configured in BIOS as Master, and the second as slave.
If there is only one drive, it should be set as master: Two drives on two different controller must be both defined as master.
Hope it helps.
Sep 07, 2009 | IBM ThinkPad 570E Notebook
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Jul 13, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Computer starts up then shuts off
make sure you pushed the ram ships in all the way.also make sure that you didnt unhook anything from the mobo when you opened your computer.
Feb 19, 2009 | MSI P4MAM2-V Motherboard
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
