Question about Hotpoint Washing Machines
FLICKERING LIGHT ON DISPLAY SCREEN HOTPOINT WT960
I have a hotpoint wt960 washing machine purchased 2007 - the display screen seems less clear and is flickering .
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
SOURCE: how do you remove the child lock off the washing machine
hold the child lock button down for a few seconds.
Posted on May 09, 2008
SOURCE: where is filter in hotpoint
I would also like to know the answer to this!
Posted on May 17, 2008
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
SOURCE: Hotpoint WT960 User Manual
Try the following link:
Andrew
Posted on Sep 18, 2008
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machine not coming on
you said the screen was flickering, it could be a problem with a faulty/loose cable/connection. between the board and display i would try this first. with the power off as electricity should not be messed with
Jul 23, 2009 | Washing Machines
I CANNOT READ THE INFORMATION ON THE LCD DISPLAY ON MY HOTPOINT WASHING MACHINE MODEL WT960 ULTIMA
some times in many m/c it has a code for the status of the m/c
i mean not complet words like F2 IT MEANS FOR REPAIR MAN THE FAULT NO 2
THANKS
Jul 11, 2009 | Hotpoint Washing Machines
Does wt960 have an eco mode?
This model does not have a specfic energy save programme, however, by selecting a coolwash at 30oC or a mini load, you will use less energy.
These features are detailed in the user instructions.
Plz rate my solution.
Thankyou.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Dec 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
258 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
