Question about Lexmark P915 InkJet Photo Printer
Paper not feeding into the printer. I gently push down on a stack of 5-10 and 20 to 30. It doesn't feed at all.
  • 241 Answers
The rollers could be worn on the printer. By having a maintenance cleaning done by a certified technician should fix this problem.
Posted on Jun 04, 2010
Canon mp280
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 13, 2013 | Canon Office Equipment & Supplies
Printer problem
May 12, 2013 | Canon MX300 Office All-In-One Printer
Paper Shooting Out
Please have a Check on the below mentioned Points and follow the steps:
Good Luck!!!!!!
Mar 28, 2013 | Lexmark X4650 All-In-One InkJet Printer
Z42 not feeding paper
Regards,
Sanath
Feb 20, 2013 | Lexmark Color JetPrinter Z42 InkJet
How can I fix a reacuring paper jam
Jan 29, 2013 | Lexmark Intuition S505 - multifunction ...
Samsung ML-2580 always paper jam
Good Luck!!!!
Oct 05, 2011 | Office Equipment & Supplies
JAMMING IN THE FINISHNER
Good Luck!!!!!
Sep 25, 2011 | Office Equipment & Supplies
Paper jam
Good Luck!!!!!
Sep 25, 2011 | Lexmark X6170 All-In-One InkJet Printer
Paper d,ont feed unblock paper but no paper stuck
Good Luck!!!!!!!
Sep 25, 2011 | Lexmark X5495 Printer
SOMETIMES FEEDS UP TWO OR MORE SHEETS WHEN IT SHOULD ONLY BE ONE
many printers have a rubber or cork pad under the feed wheels to hold back all the sheets, except the top one. This one doesn't have that, so we'll try a couple other things.
Pull the tray out and remove all the paper. If you're reusing old paper, that might be your problem. Assuming you have fresh, clean paper, take the whole stack, pinching it at one end, and bow the stack up in the middle. Now pinch the other end of the stack, relax the grip on the end you pinched before, and bend the stack the other way. Repeat.
With every bend, the stack gets more slanted. Now hold one end of the stack and fan the other end to get air between all the sheets. Fan the other end the same way. The tiny layer of air you're creating between pages goes a long way in lubricating them, so they feed separately.
Straighten the stack and put it back in the cassette. The blue "fences" at the sides should be touching both sides of the stack to provide a little friction and keep the feed straight. The back fence should hold the stack against the opposite end of the tray. (Your tray is slanted at the feed end. On models where that wall is vertical, you should have a 1 to 2 mm gap so the paper doesn't bind when it tries to lift.)
Reinsert the tray and try it out.
Dec 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
Lexmark P915 InkJet Photo Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
