Question about Bosch Exxcel WVT 2850 Front Load Washer / Dryer
Bosch dryer comes up with error code F09 - have cleaned filters and it will run again but only for a few minutes, then it beeps and the error code comes back up again
SOURCE: Error code F09 for HE3T Kenmore waher
thanks for the answers.
Here is what we did. Washed twice with no cloths in the machine - some debris came out during the rinse cycle. No more F09 after that.
Posted on Apr 11, 2008
SOURCE: Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
Posted on Mar 11, 2009
  • 3 Answers
SOURCE: Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Posted on Dec 01, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Posted on Jan 10, 2010
Macmarkus
  • 2605 Answers
SOURCE: My bosch wfk 2401 when i start the wash everything
Hello and welcome to fixya.
I'll start by saying you're right the "01" error code is indicating a fill problem has been detected by the control.
Have you tried just a "cold" water wash ? If not try selecting "quick wash" and on the dial turn it to #1 "cold" in the cotton setting see what happens. Do the same and select #3 "hot". If the error occurs in one and not the other, observe and either focus on the hot water valve or the cold main wash valve ( I don't think it is the cold prewash valve or the error would occur immediately ).
In fact I suspect it is the main wash cold valve ( dual valve ) since you haven't indicated the error occurs during prewash and the hot water valve is energized in prewash by design to help rinse out the detergent no matter what cycle or temp. you selected.
Having said all that, here's what you're dealing with. Even though you appear to have sufficient water flow as you stated you checked for, the electronic control doesn't think it is correct.
There are several factor's which could possibly be causing this error, a couple you've mentioned.
They are...
 Water supply turned off. ( obviously not in this case )
 Water inlet hose filters (strainers/screens) blocked. ( you've said you cleaned them out )
 Water pressure too low. ( must be no lower than 14.5psi and a max. of 145psi )
 Water inlet valve(s) has failed. ( this doesn't appear likely...at least at first, not completely failed based on your description...but the control may think it has. If you have an ohm meter you can check it. the coils should have a value of between 2.7 and 3.3k ohms. That means 2700ohms and 3300ohms. If not within those values the control will detect the value being incorrect , hence displaying the "01" error. Change the valve, Bosch part # 265772, or repairclinic.com # 467537.
The Hot water valve if need be is Bosch part # 171295 or repairclinic.com # 423900 )
 Control module has failed. ( Not very likely either...but possible...if not the valves. )
Let me know what you find as I will watch for your reply here. Thanks for visiting "fixya". Please take a moment and rate the info provided for you here today.
Let me know if you require further assistance.
Thanks and good luck.
macmarkus :)
Posted on Jun 13, 2010
Testimonial: "macmarkus i did a wfk 2401 washer test and when i did this portion of the test,Dual cold water valve (Pre-wash) ? Push Pre-wash button (Pre-wash light comes on). Push button again to end test. Water from left half of dual inlet valve (viewing front of washer) flows into right side of dispenser. Pull dispenser door slightly to view water (without splashing). i did not have any water at all so i do think it is the valve. do you concur? sincerely, mary"
What does error code f09 mean on a bosch vented dryer,?
F09 error is no heating, you can fix that by opening up the back and pressing the red cutout button which will restore hot air.
Jan 30, 2015 | Bosch Dryers
How to fix recurring F09 error in Bosch condensing dryer WTE86300US
How long is the connection including the duct work in the house?
Jul 31, 2014 | Bosch WTE86300US Axxis Electric Dryer
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
My dryer runs for several minutes, then starts beeping and an error code E: 01 is displayed. I've tried unplugging it for 30 minutes, but that was no help. Any ideas?
This means that the dryer is not able to exhaust correctly. Often times this is caused by kinked or blocked vent behind the dryer. If that looks ok, the vent in the wall may need to be cleaned. In this case or in most a professional dryer vent cleaner would be needed to clean the dryer vent.
One last thing you can check is the lint screen. On Bosch dryers the lint filter will become clogged from the dryer sheets. Remove the lint filter and run water through it. If water runs through, the lint filter is good.
I know this unit well and can assists you with any repair related question you have.
Let me know
Mar 26, 2011 | Bosch Nexxt 500 Dryer
Bosch dryer is beeping and showing error code, E01,after a few minutes of running then shuts off.
Clean the Duct hose mine was doing the same thing and now it will run the full cycle no problems. Also if you are in a high humidity area it may be blocking up with condensation.
Jun 05, 2010 | Bosch Dryers
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Sep 24, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
258 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
