Question about HP Laser Jet 1320 Printer
Dear all hp laserjet1320 toner missing problem replace 3 toner but given same problem check all printer and clean all sensor and replace ground card but given some problem.
  • 223 Answers
Try an nvram, hold down the right arrow and the cancel button while the printer is off and turn it back on, this will reset the sensors, and reboot the machine. Hold the down button and cancel until permanent storage is displayed and let go of the buttons, if this doesnt work it is more lilkely to be the cartridge tray and by replacing the tray the issue should be resolved.
Al
Posted on Aug 17, 2010
HP 400 Jams in duplex mode just before fuser unit. What can I do to fix? I have 3 printers doing this.
Hi There, I have found that there is a bit of toner build up at the fuser entrance, this toner is usually sticky or rock hard, this will block the paper from entering the fuser, scrape the hardened toner of with fingernail or something hard, also clean sensors and rollers using a damp cloth.
Jan 15, 2015 | HewlettPackard HP 4700 CP4005 Duplex Feed...
Sypply memory error
You have a bad toner cartridge. All HP toner cartridges have chip attached to them. That chip is read by a sensor in the printer. If the chip is missing or bad replace the cartridge.
Mar 04, 2014 | HP LaserJet M1522n MultiFunction Printer
I've got a HP laserjet 1012. I have placed a new print cartridge 12A black, but my computer still give the message "toner empty" and my printer have still the flashing red light. What i have...
I wont think so that there is no toner level sensing in 12a catridge, messaige might be catridge missing or incert catridge.. remove back door see down right side sensor which sensing the catridge presence, check sensor flag dislocate/spring dislocate/broken correct it, if sensor is dusty clean it... Best of luck
Sep 09, 2011 | HP LaserJet 1012 Printer
Large black line down middle of copies, what does this mean?
Replace the toner cartridge (Q2612A) for a new one.
Jun 27, 2011 | HP LaserJet 1012 Printer
HP LaserJet 1020 won't print. Error: HP LaserJet 1020 has the front cover door open or the toner cartridge is missing. The door is closed and the toner crtridge is installed properly. I tried to upgrade...
Did this just suddenly happen or was it after you replaced the toner cartridge or opened the door?
I have found that if the toner cartridge is not completly positioned into the printer, it can give this error.
Feb 23, 2011 | HP LaserJet 1020 Printer
Error codes 000070-001 and 00020-081 for iRC3180i
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
Toner Missing Light Error persists
use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridge.
Feb 03, 2009 | HP LaserJet 1320 Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
