Question about Brother GX-6750 Typewriter
OHow do I change the margins on this typewriter. I do not have a manual.
  • Adnan Bhatti
    Adnan Bhatti Jun 01, 2010
    Get a pdf manual.
  • 610 Answers
You can go to brother-usa.com and look for a heading labeled downloads or support. There you can download the owner manusl for free.
Posted on Jun 01, 2010
How do I change the left margin on this typewriter?
There are two levers at the back of the carriage with a small arrow mark on them. You normally depress them and slide. A bell rings when the carriage approaches the right margin.
Using typewriter
Oympia SM3 deluxe italic manual typewriter
Apr 17, 2016 | Office Equipment & Supplies
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
I do not have a manual for the IBM wheelwriter 3, but I need to know how to set margins for this typewriter. Each time I press return the left margin changes moves to the right. If I shut it off the margin...
The WW3 resets margins and tabs to default on every power up. If the margins change while you are typing then the silver shaft that nthe carrier slides on is probably gummy. A shot of WD40 on both sies of the shaft shouls free it up.
Go to lexmark.com, click on support you will find a downloadable manual there.
DickyO
May 18, 2010 | IBM Wheelwriter 30 Typewriter
I need to reset the margins of my AT&T typewriter
L. margin - return to the margin, press and release margin release key, space or backspace to desired location, press L. margin key.
R. margin - space to desired location, press R. mar key.
you can download a manual at Lexmark.com click your way to publications.
DickyO
Feb 08, 2010 | IBM Wheelwriter 30 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
SMITH CORONA KA 13 WORD SMITH
For a manual, try Google. Just put in "Smith Corona KA 13 WORD SMITH MANUAL'. If you can't find one there, then you are prabably out of luck. To change the margin simply go to the left margin, use the "backspace" or spacebar to position the print head where you want the margin set and then push the L MAR key. To change the right margin use the same procedure and hit the R MAR key.
Oct 24, 2008 | Smith Corona Wordsmith 100 Typewriter
How to change the Margins
Yurn on, carrige return to left margin. To move to the left, depress the MR or margin release key, back space to where you want margin. There usually a key that says code or mode, up on the top cover if it has not been cleaned off the 3 key is the margin left key and the 4 key is the margin right key. depress the code key and 3 key will set the left margin. Hope this helps...
Jun 10, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
291 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
