Question about Garden
Correct method to wind on the cable to the flymo mower
Correct method to wind on the cable to the cassette from a flymo easy-reel.
  • 177 Answers
With the puller in position and the reel in position just make sure there is some tension
Posted on Jun 07, 2010
My Nikon N60 wont load film. I load the film but it doesnt wind the film, but when i take a picture it rewinds it. I dont know what im doing wrong
Hi. Pay careful attention to the way the end of the film fits through the take-up reel. Open the back (empty) and give the wind knob a few twists. That will tell you which way it is turning. Put the end of your film through the slot in the take-up reel so itd winds onto itself as it advances. There's usually enough extra unexposed wound onto the factory reel that it won't cost you and pix at the end of it. Pull enough out of the cassette to be sure your winding-load position is really going to hold when you advance. Good luck.
Oct 30, 2016 | Nikon N60 35mm SLR Camera
How difficult is it to replace the pull cord on a Snapper 6.75 model 7800179
Replacing any pull cord, on just about any machine is typically a simple, easy, repair. Generally speaking you remove the plastic housing on the top of the machine and you will find it includes a spring loaded rope reel. You can usually figure out how to re rope it just by looking at it. The main thing to understand is winding up the reel so the spring is tensioned before you attach the new cord. That way it will spin the new cord back into the reel after you release it.
Mar 17, 2015 | Snapper Garden
Cut through cable on flymo how do i rewire
it best to get a waterproof cable connector then you do not have to take the flymo apart.
Apr 10, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Replace pull chord
Depends on your make and model.
Some are really easy, some impossible.
The easy ones go like this.
You remove the top of the motor, which is held on with a few screws. You will then have a bowl shaped piece, usually metal, which you will turn upside down, and see the cord-winder reel inside the top of it.
You will remove the cord winding reel, and wind a new cord onto it. However, the cord winding reel is spring loaded, and it takes knowledge and experience to do that.
The harder ones, I cannot begin to describe.
Be blessed.
May 04, 2013 | Mtd 22" Yard Machine Push Mower
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
AIWA AD-F810 reel torque
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Feb 11, 2012 | Audio Players & Recorders
HS-U510(c) Recently the tape is not rewinding. When ejecting, tape not rewound from heads and gets caught in mechanism. Defenitely seems to be some rewinding problem as noise of gears grinding and...
The problem is in the idler assembly that runs the tape and reels it in on eject, the drive belt will probably need replacing that is attached to the assembly.
Mar 27, 2011 | Mitsubishi HS-U510 VHS VCR
How do I replace the pull cord on a craftsman 6.75 HP EZ walk?
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Good luck and be careful!
Oct 04, 2010 | Craftsman Garden
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Tape won't play
I am assuming that the problem is with just the one tape...
Two things spring to mind - Either the tape has snapped or the reel lock mechanism is jammed.
1) Check the tape. With the cassette the right way up, press the little button on the right-hand end just behind the tape flap, flip the tape flap up and check that there is actually some tape there. If not, it's snapped.
2) With the cassette upside-down and with the tape flap facing away from you, you should see a small hole in the centre of the cassette about 2cm from the edge nearest you. Press something gently in here to release the reel locks. Then give both reels a couple of small turns back and forth (a finger stuck in the reel holes is ideal for this!) Before you put the cassette back into your machine, make sure there isn't any slack on the tape by gently winding any excess back in by turning the reels, but don't wind it to tightly - the moment you feel resistance, stop.
Hope this helps,
Matt
Mar 22, 2008 | JVC DF420 D-VHS Tape
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
