Question about Dryers
Dryer begins to heat and then stops - Dryers
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer begins to heat and then stops - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Dryer2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
Why does my gas dryer heat keep shutting off?
The solenoid coils on the dryer are acting up. This is a common problem. They work a little then heat up and short out. Easy fix I did some videos:
How it works
Replacement
Jul 22, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
Dryer starts (heat on) after 5-8 minutes heating cycle stops and only cool air run through.
your heating element need to be cleaned.......
1. pull the unit out from the wall
2. Remove the screws holding on the larger rear panel.
3. Using a vacume cleaner extension, remove as much debris as possible from all accessible components.
4. Clean out the dryer vent and the connection to the wall, making sure that air can pass easily.
THAT SHOULD DO YA. If the heat continues to cut off, you are dealing with a faulty heating element in which case you will be best off to purchase a new dryer. (replacing a heating element is typically the beginning of a failing unit)
GOOD LUCK AND PLS RATE THIS POST!!!
Jun 03, 2010 | Kenmore Dryers
Our dryer takes a long time to dry clothes. If the airvent that goes outside of the ouse is clogged...would that affect the dryer? Stupid question i know, but we have like 5 feet of snow outside, so it's...
Yes this would affect try time as your dryer is not able to move the moist air out of the dryer. That is probably your problem. The other issue would be gas coils if it heats at the beginning of the cycle and stops heating towards the end.
Hope this helps _MJ_
Feb 07, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 | Dryers
Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Feb 08, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer heats up and then stops heating dryer heats in the begining, then cools off the rest of the cycle.
hi .thanks for the question. the problem. is with the coils on the gas valve .replace the 2 coils. should solve your problem thanks the appliance doc.if you dont know how to do this get back to me
Oct 02, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
