Question about Fisher and Paykel GWL11 Top Load Washer
Not draining completely - Fisher and Paykel GWL11 Top Load Washer
  • luisa_sgro Jun 02, 2010
    sounds like your pump is blocked. where is the water draining into. is it into your laundry sink or to the s bend on you laundry sink tub?does you machine have an efficiency button?please reply and i can guide you throe the removal of the pump to clear it if it is blocked
    Problem Solver:
  • 5 Answers
There is a service summary with error codes under the control panel in a zip lock bag. My pump was being blocked by a bobby pin. removing the basket allowed access to the pump and I was able to clean out the suction. I was amazed by the scum build up under the basket. I will now remove the basket yearly to clean under it.
Posted on Jun 02, 2010
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Bosch 4000 dishwasher does not drain completely
I am not sure what "completely" means because none of them drain the sump area completely. If you mean water is visible above the filter, then cleaning the filter or checking for drain obstruction is in order.
Dec 28, 2014 | Bosch Dishwashers
DISHWASHER IS NOT DRAINING COMPLETELY, LEAVING ABOUT 2 IN OF WATER
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | KitchenAid KUDS301V 24 in. Built-in...
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Daniel
Aug 30, 2011 | Dishwashers
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
Fisher and Paykel GWL11 Top Load Washer Logo
131 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
