Question about Nokia 2600
ON SWITCHING ON THE MOBILE IT IS DISPLAYING RANDOMLY DIGIT 6 WHICH IS NOT PRESSED BY ME. THIS HANGS MY MOBILE 2626 NOKIA
  • Nokia Master
  • 4,737 Answers
Please take it apart using six sided (small for nokia mobiles) screwdriver, remove the cabinet and Switch it on whether the same problem persists or not. If the problems still persists, the you can check the keypad with the number 6. It must be stuck, you can remove the tape which is covers the keypads, and check it. To find the key no. 6, refer to the keypad and take action with the corresponding key. Do whatever is needed like cleaning, removing etc.. and again switch on before you close (fit) the cabinet. If it's ok, you can fix the screws and the cabinet (housing/case). If there's is nothing wrong with the key, then there're must be internal problem. You better go to a mobile repairing shop and get it repaired. In case the problem goes away, then replace your cabinet. It's the problem with your case, perhaps it might have been broken somewhere. Good luck. Thanks for using FixYa.
Posted on Jun 01, 2010
I need free unlock restiction code nokia 2626 emi 354194032285663
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 04, 2012 | Nokia 2730 Cell Phone
My nokia 2626 mobile phone is hanged . so please tell me how to install software , so that i can use it properly.
You can use memory up full edition. It can be found in mobiles24.com. It helps your phone boost its RAM memory to prevent hanging. If it doesn't work, it means that your phone has a threat. I hope it can help you.
Jul 17, 2011 | Nokia 2626 Mobile Phone
NOKIA 2626 displays "PHONE RESTRICTED".
sir plz help nokia 2626 phone ..display phone restricted
Dec 22, 2010 | Nokia 2626 Mobile Phone
I want to restore the factory settings of my nokia 2626, so i need the code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 6 Digit Security code: 000999 or 1122
Oct 22, 2010 | Nokia 2626 Mobile Phone
Restriction code for nokia 2626
Sep 06, 2010 | Nokia 2626 Mobile Phone
How to restart nokia 2626
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens.nokia 2626 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - nokia 2626 mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent nokia 2626 from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling nokia 2626 phone memory.
Cause 3 - Memory Cards - Some people have reported that nokia 2626 restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their nokia 2626 mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your nokia 2626 phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this
Good luck
Jul 09, 2010 | Nokia 2626 Mobile Phone
Cost of changing the display of Nokia 2626 mobile
The cost of changing the display is around,
10 Pounds.
You need a T-6 Torx Skrevdriver to remove 6 skrews,
to loosen the broken display.
here you can order your display for a fair price:
http://www.mytrendyphone.com/shop/search-1.html?keyword=display+nokia+2626
Please vote!
Mar 19, 2010 | Nokia 2626 Mobile Phone
Nokia 2626 mobile display is not working
the only solution to this problem is changing the screen.
The screen is faulty that's why its blank and cannot display anything.
So go ahead and change the screen and your phone will be back to normal.
Take care.
Mar 18, 2010 | Nokia 2626 Mobile Phone
Mobile gets switch off while pressing go to key
flash with latest flash file it min's software fault
May 09, 2009 | Nokia 2626 Mobile Phone
Nokia 2626 contact service
SOLUTION NOKIA 2626 CONTACTE SERVICE
Jan 27, 2008 | Cell Phones
Nokia 2600 Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
