Question about Theater Research TR-2800 Main / Stereo Speaker
I have the opportunity to buy a used (4 years) a couple TR2800 speakers for $ 600.00. I do not know the price of new ones. Is it a good opportunity? Thank you.
Pass on them. There are are better loud speakers out there for that price.
Posted on Nov 22, 2011
My alarm clock quit working what can i do ?
In my experience, you only have one choice: buy a new one. I have gone through 4 new alarm clocks/clock radios in the past 2 years. It seems as though you can buy a $20 unit, or you can spend twice that in attempting repairs. These devices are just not made to last more than a couple of years, if that. Good luck in finding one that will "keep on ticking" like they used to.
Feb 09, 2016 | Audio Players & Recorders
How to install aftermarket radio in 2009 mazda 6
The smartest thing is spend the money and purchase vechial adapter pigtail made specially for your brand of head unit and presided connector for a easy plug and play, from crutchfield.com. No guess work no schematics or wiring diagrams to follow plug in connector to vehicle harness and back of your aftermarket stereo put the couple plastic pieces of trim and your done. The support side of crutchfield.com is a very good resource. But if you don\'t want to spend the cash for pigtail, you can create account on auto zone.com and go to vehical repair guides and click locations. Why electrical schematics are in the tab labeled, locations, is beyond me. Print it and it will give you the speaker color codes and wire functions with connect pin location numbers. Just remember the industry standard, except for couple exotics, is that first color listed is the main color separated by a /, forward slash, and followed by the color of the strips. And japain cars occasionally use a stopped lines. Same color codes as if solid stripe. Auto zone also has the manufactures service procedure of how to properly remove old stereo unit with out damage. If your car is too new for auto zone listing then I suggest pay $20 to alldatadiy.com as a mechanic the shop pays $1500 a year subscription for alldatapro.com which has all the manufacture procedures, tsb\'s, schematis, and locations, but for twenty a year per vehicle you have access to all the same information as the mechanic in all non dealership associated shops.
When doing wiring always use soldering iron, pencil snapped, not a wiring gun. Gun gets too hot unless your building battery cables. Walmart got one for something like eleven bucks. And use double walled heatshring for 16-22gauge wire. Double wall has heat activated glue that makes water tight seal.any corrosion from water corrosion will be noticed as distortion or noise in stereo system. Are you installing amplifiers or subwoofers? For the pound chest felt thump? Are you using factory speakers? What wattage are speakers? And measure resistance with digital multimeter or use speaker impedence Value. Head units only produce up to a 4 volt constant variable frequency and current to transmit signal. The 50watts x 4 channel is not 50watts per speaker its true my 50 watts peak and 1/2of peak watts of RMS WATTS AT 25. AND DEVIDED BY FOUR SPEAKERS IS TRUELY SOMETHING LIKE 6.5WATTS OR SO. NO IM NOT GRABBING CALCULATOR, 6*4=24 SO A FUZZ OVER. I HAVE FOUR SIX BY NINES RUNNING OFF A 4 CHANNEL 600 WATT RMS 1200 WATT PEAK DUAL MONOBLOCK AMP RUNNING AT 4 OHMS PER SPEAKER WIRED IN PARALLELD EQUALS 2 OHMS OHMS PER BLOCK AND TOTAL OF 4 OHM TOTAL CIRCT LOAD OHM WITH ALL FOUR SPEAKERS USING BOTH BLOCKS. THE 600 WATTS IS RMS OR HALF OF PEAK AND WHILE USING DUAL MOMOBLOCK MEANS ONLY 300 WATTS PER EVERY 2 CHANNELS AT 2 OHMS. BUT IM WIRED AT FOUR OHMS AND OHMS LAW SAYS TO DOUBLE IMPEADANCE OR MEASURED CIRCUT RESISTANCE YOU NEED TO DEVIDE WATTS. SO 150 WATTS PER BLOCK. AND DEVIDE FOR TWO SPEAKERS AND GET 75 WATTS. SPEAKERS ARE RATED AT 90 WATTS, THANKS TO NEWEST 6X8 INCH, YA 8, 4WAY FULL RANGE SPEAKER. 4 WAY MEANS HAS FOUR SPEAKERS BUILT INTO ONE TO PRODUCE FOUR DIFFERECT FREQUENCY RANGES. STAY AWAY FROM COMPONET TYPE SPEAKERS AS YOU,LL HAVE TO MATCH IMPEDENCES, AND WIRE THE THREE OR FOUR SPEAKERS TOGETHER TO MAKE THE ONE FULL RANGE SPEAKER WITH CAPACITORS. AND ... ON AND ON. SO IF USING OEM OR ORIGIONAL MANUFACTIOR EQUIPTMENT, SPEAKERS YOU SHOULD NEED TO KNOW IF THEY ARE COMPONET OR FULL RANGE. AND NEWER CARS HAVE THE AMPLIFIER AND ALL THIS MATH MATCHED TO PROPER RATED SPEAKERS. AAN WELL AS A CFEW YEAR OLD VEHICAL MAY HAVE A 1200 DOLLOR KENWOOD IN IT WITH BUILT IN AMPLIFIERS THAT AFTERMARKET SYSTEMS DO NOT HAVE. BUT NO TAG SAYS THAT. IT\'LL SAY DELPHI FOR CHEVY MOPAR FOR CRYSTLER , MOTORCRAFT FOR FORD, AND SO ON. SO. HOW FAR DEEP DO YOU WANT TO DIVE? THE MONEY SPENT ON CONNECTOR ADPTING HARNESS FROM CRUTCHFIELD MAY HAVE JUST PAID FOR ITS SELF. IN STRESS AND ****** OFF TIME SPENT. AND THEY HAVE GOOD PRICES ON HEAD UNITS, SPEAKERS, DASH ADAPTER KIT, FOR PLASTIC SIZE AND MOUNTS FOR THE DIFFERENT SHAPED UNIT, AND GIVES A DISCOUNT IF YOU BUY THE UNIT AND ADAPTER HARNESS TOGETHER. WITH FREE SHIPPING A LOT OF THE TIME WITH AMAZING SUPPORT PAGE, CRUTCHFIELD IS THE PLACE TO GO FOR MOBILE AUDIO.
Crutchfield Car Stereo Speakers Home Theater LED LCD TV Cameras AutoZone Auto Parts Accessories Repair Guides More ALLDATAdiy com Leading Source of Factory Automotive Repair Information
May 15, 2014 | Cars & Trucks
Teledyne laars series 2 model esg
unless its free, dont waste money on used gas appliances. unless you have it fully inspected, dont bother
Apr 04, 2014 | Pool & Spa
Replace bulb cmw-200
i need to change a bulb on the cuisinart convection oven cmw-200 and i don't know where to find it
Feb 23, 2014 | Cuisinart CMW-200 Convection/Microwave...
I have the opportunity to buy a used Westinghouse w3223 LCD tv - what can you tell me about it and how much is a fair price to pay for it? It was made in June 2008
Hello...This tv sold for about $535 retail back in 2008...It was considered a great set with good consumer reviews...but you must consider that the set is 4 years old and depreciated in value...also HD tvs...much like computers have become better and more affordable...Myself...I wouldn't pay over $200 or less because I'm sure there is no warranty and if I pay over $200 for a 32 inch tv.....It will be new....If the seller won't sell for under $200...shop around....I would start at $150.00....I hope this was helpful...let me know what happens....PEACE.......PS...b4 you make an offer...see how much the seller is asking......Cool!!!
Mar 01, 2012 | Televison & Video
I have the opportunity to buy a used one of these telescopes it is not the new version and has a black metal body and is just a simmons not including meade in the name. The main mirror is misalighned but...
DO NOT BUY that toy telescope! Instead save your money and buy something like this with 6 inches or 8 inches of aperture.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Oct 26, 2010 | Optics
Partner x8c problem
I have a problem with my Partner X8c translator, which scren after three years of using stopped to work properly. The batteries are new. Do you know any repair service opportunities? I want avoid buying just a new translator as they are really expensive and should be able to work longer then three years.
Aug 11, 2009 | Ectaco Partner ER-X8c Dictionary /...
I want to sell my Pioneer 10'' 350W BAND PASS BOX Car Speaker
Search google the model of the pioneer, and try and find a used or new price and go from there.
Boxes are cheap and can be picked up locally anywhere for around $20-30 bucks used so dont charge a rediculous amount because it has a nice box.
For instance if your sub was $100 new. and then you bought a box for $30-50 new.
i would probably only sell it for $80 Max that is in PERFECT condition not blown or anything.
nobody will buy something that is $20 cheaper than retail priced especially if it is used.
I have been in sales and online sales for years.
Selling used items your prices stay low so the sale can happen. Priced to high people will just go buy it brand new if they want it.
I would recomend selling through Craigslist.Org. Local and easier than Ebay
Feb 10, 2009 | Pioneer Car Audio & Video
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
HP 2600n crackling noise at top feed - paper creased
Can you wipe the toner off the page or smear it? Most likely the fuser has had the fixing film fail. Thus the crackling noise. You have two solutions, 1. replace the fuser with a ne or rebuilt one or 2. find a fixing film and replace it yourself. Both jobs require removing the fuser which means disassembling the printer. Check Printer Works for a diagram and Google for the best price on a fuser. Hope this helps.
Sep 01, 2007 | HP Color LaserJet 2600n Printer
Theater Research TR-2800 Main / Stereo Speaker Logo
177 people viewed this question
Top Theater Research Audio Players & Recorders Experts
David Payne
David Payne
 Grubhead
Grubhead
Tom Chichester
Are you a Theater Research Audio Player and Recorder Expert? Answer questions, earn points and help others
