Question about Sony PSP (Piano Black)
My psp when I open the psp theres nothing but sometimes when I open it without battery and put the charger and it shows up then i put the battery it works so sometimes I do not close the psp
    Problem Solver:
  • 16 Answers
Lets try that again...
I take it by "open up" you mean when you power on your psp yes?
by "there's nothing"do you mean blank screen? no power light? no loading?
From what i make of it your psp is not loading when the battery is inserted only, it will load when the battery is removed and the charger is plugged in only. After it has loaded you are able to insert the battery and remove the charger and you try to keep your psp running continuously so you don't need to take the battery out.
If I am correct in my interpretation you have a faulty battery that should be replaced.
Posted on Jun 06, 2010
Psp wont charge or tunr on
Did you put the battery back in? Just checking. This sometimes happens with the PSP's. The charger it's self looses the ground. Try plugging in a car charger, or use a charger that will charge the battery out of the PSP.
Feb 15, 2014 | Sony PSP-2001
My psp go making problem nowmy psp go no display only green light showing
Try my advice by following these steps:
First of all remove your battery of your psp model which is found at cover of backside of casing. Then plug-in charger into it and turn that charger on.Be sure that your Battery isn't inside. then open charger PSP will open. now you can do anything in it but do not remove charger but if you have hacked it with some software then go to its options and click on make normal battery to play psp with the help of battery.
Nov 19, 2012 | Video Game Consoles & Games
When i was playing my psp it suddenly turned off so i thought it is out of charge.i charged it then i saw it was full charge so i unplug the charger when i unplug the charger it suddenly turned off.It only...
It sounds like you have either a dead (broken) battery or your battery isn't making good contact with the motherboard.
Remove your battery and make sure there is nothing stuck in the terminal slots. Also make sure the metal contacts in the batter chamber of the PSP are clean. Then replace the battery.
Give it a little extra push on the back of the battery after you put it in near the battery terminals to make sure you get a solid connection.
If it still doesn't work then you may have a bad battery and will have to replace it. They can be found on ebay fairly cheap. (dont buy the $3 ones though they last about 10 minutes.)
Apr 01, 2011 | Sony PlayStation Portable (PSP) Console
My sony psp go wont charge...
Try a different outlet in the wall, it might be the outlet. If it isn't the outlet, maybe it's the power cord. Try to use someone else's PSP charger and see if it works. If it If it's not that, then it's your PSP. If you had it since launch then it will cost $90 to get fixed.
Jan 10, 2010 | Sony PSP (Piano Black)
I can't charge my PSP
u can't charge your psp hmm there are only two ways this can happen (and both includes buying and going to a technical store) first there are some problem for your charger in this case buy a new charger second there is some problem with psp so give it for refurbishment then also try this first reboot and take out the battery put in charge cable charge without battery and in then put the battery in
Nov 25, 2009 | Sony PSP (Piano Black)
My psp slim has no power
check your charger if it's inserted well and the battery, if still not go to the sony repairing shop to help you fix it. thanks!
Dec 05, 2008 | Sony PlayStation Portable (PSP) Slim...
Ok i just bought a new psp slim battery and a new charger and my psp wont charge and i dont know what to do but, i do have a psp slim 2001 (ice silver) and i bought a psp charger and battery thats 2000 so...
this is easy i solved it! buy a charger from gamestop that you have to take the battery out and then put it in the charger and charge it that way! that way if your fuse inside your psp is out it will charge the battey without putting it in the psp so all you do with the item is: take your battery out, put it in the alternative charger from gamestop (does not come with psp slim 2001 or 2000) plug the charger in the while charge the battery then bam!! there you go problem solved have a fun time playing your psp!
Apr 12, 2008 | Video Game Consoles & Games
Sony playstation portable
It might be a problem with your battery pack, you can even switch on your psp without battery pack, with the charger plugged in acutally. So a replacement battery will be a good choice for you.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
No power (orange) charge light
Hi there, I am assuming that it was working ok until you tried to charge it then?? I have come across this problem before and you are right about the fuse, there is a fuse on the charge/power circuit that is located in the very top right hand corner of the motherboard, next to where the black power lead attaches to the motherboard - if you repair or bridge that fuse then it will work fine assuming that like I said at the begining it was working before you put the wrong charger in. If you cannot repair that fuse then the console will work fine if you can charge the battery without using that PSP (i.e. another psp or third party external charger) as there is no fuse on the battery circuit as there would not be a surge in power unlike the mains circuit. If you need more information or if this reply is not clear then let me know and I'll get an image of the fuse you need to repair.
Aug 30, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
