Question about Dell Inspiron 6400 Notebook
Power supply dell inspiron 6400
The power supply has failed. I have cut off the plug and I have another power supply from an old Dell but I have 3 connections on the plug of the new Dell and do not know the polarity can you help me please
    Sergeant:
  • 356 Answers
Get a tester and check the continuity of the wires on both ends of the plug...the 3rd wire is usually connected to ground but it's optional..it doesn't pose any danger to your system...
Posted on Jun 03, 2010
Dc jack broke. tech guy replaced but now none of my 3 power bricks will charge the battery. they all give power to run laptop but do not charge battery. when boot up get error message saying I connected an...
It is possible that it could be a bad solder joint. It could also be that the connector is a different one. Some laptops use a dual voltage power structure. On the Inspiron E1505 (same as the 6400) I have it requires the dual voltage power. This is where the outside of the plug is the ground and the inside of the plug is one voltage and the center pin is yet another voltage. In this case, (if I remember correctly) the inside of the plug is like 19.5 volts and the center pin is like 9 volts. The inside of the plug supplies the power to the laptop and charging circuit and the center pin tells the laptop that the power adapter is plugged in and should start charging. If the laptop recognizes the Vostro power supply then this is a good possibility. Either way, it is worth getting it checked out. The last thing you want to do is burn out the charge circuit on the motherboard by having the incorrect power supply plugged in to it. It may work for a while or it may work forever but you never know.
Dec 24, 2009 | Dell Inspiron 6400 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 laptop battery isn't charging, I think :(
Debby
Try booting without the battery installed. You probably will have no change but this eliminates the battery as a source of the problem. If it doesn't boot and you are sure that the external power supply is ok, you probably have a bad motherboard. At that point, the unit needs to be checked out by a pro or a really competent amateur.
Aug 01, 2009 | Dell Inspiron 6400 Notebook
DELL INSPIRON 6400 WILL TURN ON BUT WONT CHARGE
I would try checking the power supply first before replacing the battery. The power supply is much cheaper and sometimes interchangabel with other models. Also try cleaning and reseating it. If you do end up needing a battery though dont buy it from dell. get it on ebay, amazon or a decent priced online store for best prices. If you're lucky you could get another one for about $20 or $30. good luck
Jul 13, 2009 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Flashing icon at the top right of my Dell Inspiron 6400
seems your battery cell is the one having that issue. try replacing the battery or plug the laptop and let it recharge the battery to full.,
Oct 28, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
