I use Pinnacle Studio 14 to edit video & burn DVDs. However,when I have included a menu it will not play on the Sony DVD recorder/Sony Bravia combo, but gives error 1080i. Yet it plays ok on my computer and a Sony portable player! Commercially produced DVD with menus play ok. Sony have not been very helpful! Do you have any clues? Rick Nauta
  • 12,061 Answers
OK, well some software programs, for whatever reason, record and playback, these "Previews" "Menus" parts of the DVD burn, and they are only burnt, in a very low res format, or a Format, that's not quite up to the one that works, when you choose the item from the menu, it then switches to HD or whatever,, now some players and software simply cannot, "Understand" that transition, from low res, to what it expects, or the signal levels used to communicate what's going on aren't quite right and the unit, hangs up. Now some players, just plough on and don't care the res, or codec or whatever, but some as said just get overloaded, probably from error correction, this causes it to freeze and not work. It's all got to do with CODECs and Formats.
Posted on Jun 01, 2010
  • nauta1 Jun 01, 2010
    Thank you for a rather "vague" explanation; I am not using HD and it has worked before, so what is the meaning of a 1080i error and more importantly: what is the solution?
    Regards, Rick Nauta
    Jun 01, 2010 - Hi,
    Regards, Rick Nauta
Why does my dvd freeze frame after using pinnacle 14?
I have made about 5 DVD's all under a half hour and just made one over 45 minutes and am having the same issue. When I play the DVD, it will freeze in the same spot about 15 minutes into the movie. I have read that using a different burn tool instead of Pinnacles may work. Also, de-install the software and re-install. I have not tried yet, but will let you know. After doing some quick searches, this is a common problem with Pinnacle.
Jul 24, 2012 | Pinnacle Studio 14 HD
Pinnacle Studio Ultimate 14 - I can't get video projects to burn. Photo projects work well. I use Dazzle to load video from a vhs into Pinnacle. Seems to work well and I create a project. When I go to...
A general workaround would be to let your software create an ISO image instead of burning a disc. Then burn the ISO with a known-good burning software (many user here - me included - recommend ImgBurn).
Feb 17, 2011 | Pinnacle Studio Ultimate 14 for PC
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? ...
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Sep 13, 2010 | Computers & Internet
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Sony Handycam DCR-TRV250 driver for windows 7
hello .. how can i connect my handicam in windows 7 and copy my tape from handycam to my laptop..???
tanx
May 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
HOW TO BURN MOVIE ONTO DVD WITH MY COMPUTER
Windows Movie Maker has a few features that are missing for it to complete the job, In fact Microsoft no longer supports the product. This is why it's not included in Vista. Nero makes software to do it as well as Pinnacle. I use Studio and it will walk you through the capture process, edit, menu creation, and burning to DVD.
Feb 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Copying video to DVDs
yes there is a program called ulead dvd moviefactory you could import all from camcorder and import to movie factory as I use pinnacle studio to import and ulead movie factory to export to dvd format hope this has helped
Aug 13, 2007 | Sony Handycam DCR-SR100 Camcorder
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
