Question about GE Profile PFS22SBSS Bottom Freezer French Door Refrigerator
GE profile pfs22miwaww runs all the time, unit is hot to the touch, freezer is up to 23 degrees and the condenser fan only runs very slowly (coil is clean). I put a small fan behind the unit and it worked normally
  • terrysievers Jun 01, 2010
    I forgot to mention that the fan turns freely and I oiled it anyway. sorry
  • GE Master
  • 3,740 Answers
You may be able to just lubricate your condenser fan. There is a lubricant called "Zoom Spout" that is a paraffin based oil that you should use to do the lubrication. The oil is available at most appliance parts sources and usually at the Sears parts service counter. It is less than $3.00. You need to oil then wipe the armature shaft clean by gently tugging on the fan to lift it and wipe again and then re-oil the shaft front and rear of the condenser fan motor. The fan bearings get dirty and cause the fan to run slow. Any other type of oil will work for 30 days or less and then it will start running slow again. Just use the correct lubricating oil the first time and save yourself some money and time in the future.
Some of the condenser fan motors you can remove the bearing mounting hardware and slide the bearing up on the fan motor shaft to allow for cleaning the gunk off of the shaft that is causing the bearing drag. If you do take it apart note the bearing mount positions BEFORE you take them apart. I usually scribe one side of each bearing mount in a different place so that you do not install them backward.
Thanks for using FixYa.
Kelly
Remember (Zoom-Spout oiler and there is a tube that pulls out of the oiler for use. Do not pull it out all the way!)
Posted on Jun 01, 2010
  • 2 more comments
  • Kelly
    Kelly Jun 01, 2010
    After looking up your condensor fan:
    http://www.appliancepartspros.com/part_d...
    it is the newer style fan that does not have the removable external bearings. Most likely the only remedy is to replace the fan at this point.
    The fan detailed view is above but item 812 of this link:
    http://www.appliancepartspros.com/partse...
    I would also check the condition of the rubber gromment item 102 of the same link. Order the gromment also if it is bad shape.
    Kelly
  • Kelly
    Kelly Jun 01, 2010
    The reason you will most likely have to change the fan is on this type of fan the motor bearing wears and the silver part of the armature shaft starts dragging on the stator case causing it to run slow. If you can gently move the armature shaft in all circular directions and it touches the case as you move it, the only option when it is dragging on the case is to change the fan.
    Kelly
  • Kelly
    Kelly Jun 10, 2010
    Just doing a follow up..... Re-read everything and have one more thought.... IF the condenser fan is running at full speed and the unit is running HOT there is a very real possibility that the evaporator coils have frozen solid with ice due to an automatic defrosting circuit problem. Or... the evaporator fan in the freezer compartment itself is not turning fast enough. I did not see any resolution of your problem to date.
    Kelly
  • Kelly
    Kelly Jun 11, 2010
    Final comment unless you respond. The fan can be running at full speed BUT if the condenser coils are clogged with lint or hair the unit will be hot to the touch and will not cool properly. I just serviced a unit yesterday that had this exact problem and the problem was that there was about 1 inch of lint on the opposite side of the condenser coils not allowing airflow through the coils. Some thorough cleaning / fan lubrication and the unit is operating normally.
    Kelly
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
Hi, I have a GE side by side GSS23LSTA refrigerator The last few days it has been running constantly. The refrigerator side temperature is fine at 35 degrees, but the freezer temp is staying at around 12...
Hi Mark and welcome to FixYa, I am Kelly
Touch the front of the unit where the doors close and feel if it is very very warm to the touch. If it is very warm to the touch... here are the prime suspects:
1. condenser coils covered in lint
2. condenser fan not running or running slow.
An easy way to determine if there is a condenser fan or coil fan problem is to simply direct a floor fan at the base if the refrigerator. If it cools down substantially in an hour.... there is a problem with the coils being clogged or the condenser fan not running. If that makes no difference... before opening the back of the unit... inspect the back wall of the freezer compartment for any signs of ice build up. If you see ice-build up.... unplug the unit.. remove freezer contents and direct that fan into the freezer compartment for just over 2 hours. Then return the unit to normal service.... If the temps come down to normal... for 2 - 3 days then start creeping up again... you have an automatic defrosting problem.
Forgot to mention... make sure the evaporator fan is running at full speed.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE profile arctica refrigerator and the fridge is staying about 45 degrees, Freezer is staying about 23 degrees, can't get it to cool down on either side. Have taken the back of the thing and the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE PDS22S refrigerator. The surface of the unit around the front of the freezer compartment is extremely hot--the front surface between the refrigerator and freezer is so hot I could not hold my...
My older frost free GE Profile gets VERY hot on the sides and on the top during part of the cycle.
Is your temp indicator picking up the heat from the cycle? Check actual temp using a thermometer...hardware store should have one.
Are doors competely closed on the unit? No Food or plastic wraps/bags in the way?
Is the fan working properly, not squeaking or squealing?
Mar 23, 2017 | GE Profile PDS22SBRR Stainless Steel...
GE Profile Arctica top freezer: freezer and fridge have been too warm all day. The freezer is 40 degrees and fridge is 46 degrees. Adjusting the temp does not help. Please help
Hi,.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 26, 2010 | GE Profile Arctica Stainless Steel Top...
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Nov 29, 2008 | GE Refrigerators
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
GE Profile PFS22SBSS Bottom Freezer French Door Refrigerator Logo
478 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
