Question about Sony VAIO VGN-NR220E/S Notebook PC
Wireless button dose not turn on
The wireless function is not working. The switch is in the on position but the green light is out.
  • 8 more comments
  • Anonymous Apr 21, 2008
    the same problem
  • Anonymous May 19, 2008
    my wireless button is in the on position but won't work. When i diagnosis connections problem...it says to turn on the wireless button.
  • jamisonkoran Jul 09, 2008
    i have the same issue, wireless function just stopped working, switch is on, no green light, no network
  • amysaysily Jul 18, 2008
    my wireless button does not turn on. its not showing light. i dont know what to do! please help meeeee thanks
  • Anonymous Jul 22, 2008
    the same problem
  • shawn411 Aug 28, 2008
    sAME PROBLEM tHIS IS THE MOST AGGEVATED I HAVE EVER BEEN WITH AN INFERNO MACHINE. SONY LOSING ITS TOUCH?
  • sjaakzwart75 Dec 13, 2008
    wireless is not working. swith is on. whre can i find more information to solve the problem?
  • dkinney Dec 14, 2008
    My Sony laptop does the same thing. I go in and turn the network back on as directed and when I reboot it drops the newwork again. Driver shows up, network adapter is there and updated, but will not connect. I have even gone as far as to uninstall and reinstall the network card.
  • Anonymous Jan 26, 2009
    I have the same problem...is there a function key action that can turn it on and off that is not indicated on the keyboard? I have another laptop that has both switches, keyboard and slide switch.
  • fady904 Jan 30, 2009
    Same problem here, when i play with button "move left & right" at some point it will light back on but all of a sudden back off again. I think this is hardware issue.
I think i got it! i had the same problem a few days ago. go to the network and sharing center in vista. then on the left pane, click on the "manage network connections" link. at the bottom should be your wireless connection. right click on it and at the top of the little menu it should say enable. and viola vaio, your little green wlan light should come on and it should connect to your wifi network. :)
Posted on Jul 31, 2008
    Novelist:
  • 92 Answers
Perfom the steps mentioned in the below link page. Also click on the blue color sub links provided on the page to view full steps.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C1000102
If issue persists, install the VAIO Smart Network Update from the below link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR220E&upd_id=4208&os_id=28
Posted on Jul 12, 2011
SONY Support provided me with this solution, which worked:
Could you make sure that the WLAN has been enabled in Vaio Smart Network?
To do this:
1. click on Start
2. type "Control" in Start Search bar
3. click on Vaio Control Center
4. in Categories expand Network Connections
5. double click on Vaio Smart Network
6. additional icon (two arrows) should appear in the Taskbar (next to the clock)
7. double click on the icon and double click on the box next to WLAN
8. should go green
9. test the connection afterwards
Additionally, please make sure that the following update has been applied:
http://support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=V AIO/Updates/EP0000144796.exe&ip=EP0000144796.htm
Posted on Sep 10, 2008
Ditto, this is frustrating, any solutions y'all? I need to connect to the internet and do an important paper for college...ahhhhhh!!
Posted on Jul 28, 2008
I have exactly the same problem as well.
Posted on Jul 12, 2008
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
I cant get any wireless signals because its says wireless capability is turned off it says to use the switch to turn it on but there is no switch. how do i turn it back on
Depending on your operating system, you can often just troubleshoot the problem and Windows will automatically turn your wireless adapter back on. If this doesn't work, it's likely that there's a physical switch on the laptop that needs to be in the "on" position otherwise it won't work. It may also be a function key combination. If this is the case, look for a little wireless symbol on your F1 through F12 buttons, then hit the function key "Fn" (usually right next to Ctrl) along with the appropriate wifi key and it should re-engage.
Mar 05, 2011 | Acer Aspire 4520-5582 Notebook
Hi my Belkin N300 wireless moden router works for about ten minutes, then the green light turns to a flashing orange. Any tips on why this happen and any solutions. It dose get a bit hot dose this make a...
If the green light is one of the port lights, then your network is switching into 10mbs (Orange = 10mbs, Green = 100mbs) - it may be a dodgy cable but more likely a faulty network card in your PC.
Feb 18, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
Wireless light not lit
The wireless functionality of the router is no longer working. The light is always turned on on all wireless routers
regards
Sandeep
Nov 24, 2009 | 2wire 2700HG-B Router (2700HGB)
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Sony VAIO VGN-NR220E/S Notebook PC Logo
447 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
