Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
The dishwasher is running but there is no hot water
I have taken it apart and clean all the fittings, the cycle runs okay and there is no error code showing but the water isn't hoyt so the pots don't clean properly
    Problem Solver:
  • 5 Answers
Maybe the hot water has run out, check, if not then the pipe out and replace it
Posted on Jun 01, 2010
Dishwasher
sounds to me like the pump is not working as good as it should . water pressure runs the arms .look for something plugging it
Dec 13, 2015 | Dishwashers
What is meaning of E 11 code at the end of the cycle
What model number?
E11 frequently means that the dishwasher is running without heating. If your hot water is hot, and you don't sanitize your dishes and they are coming clean, you can safely ignore it. It could be a loose wire or the heating element is dead. It is part of an assembly and usually not separately replaceable. If the heat is not running, the error likely comes after a period of time during which the water does not heat. It could also be a faulty sensor, usually part of the same assembly.
If you dishwasher works and is old and still cleaning, it is probably not worth fixing this.
Oct 18, 2014 | Bosch Dishwashers
Dishwasher takes a very very long time to wash
It could be that it takes a long time for hot water to reach the dishwasher so it fills with cold water. the control may wait for the water to warm up before advancing. Try running the water at the sink until warm before turning on the dishwasher. This may fix the problem. Some models have a water turbidity sensor and will wash until the water is clear. Excessively dirty dishes will cause extended run cycles.
Oct 07, 2014 | Dishwashers
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
Dishwasher won't drain. runs through normal cycles, and then just stops still full of water on the bottom. I have taken it apart and can't see any obstructions.
is there a clog in the hose somewhere because when ours clogged it would not drain it just kept circulating water all over the clean dishes and it was gross
Jan 03, 2011 | Frigidaire 24 in. FDB635RF Built-in...
The dishwasher will start to cycle. I can hear the water begin to run. I hear a click and at the time the dishwasher should start to run the cleaning cycle. During the cleaning cycle the dishwasher will...
This is probably okay, you have clock like motions running the motor electric contacts. There needs to be a delay between some cycles or shorting will occur. The motor on some designs, for example. is reversed to pump out water. to have this work long term, a delay is inherent and not a concern.
Sep 17, 2010 | Viking 24 in. Professional Series VUD040...
Lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Feb 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Sandy glasses
Are you making sure your heater is ok??Water temp should be taken and be 120 or hotter.If its not turn up water heater temperature.If heating coil is not working replace it.It provides the heat to the D/W and aids in the heated Dry cycle.The solution for spotted/foggy glass problems all  start with making sure your water is Hot enough.Rinse aid is the second.
May 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
103 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
