Question about Samsung J700 Cellular Phone
When i slide up of my samsung j-700 mobile 3
When i slide up of my samsung j-700 mobile 3 keys (right upper key, delete key, call accept key) dont work , but when i slide down all keys work properly..... how can i fix the problem plz help me ..waiting for ur response
J 700 open the camera please slide up problem
Posted on Oct 19, 2010
Auto keypad lock not working
Posted on Aug 24, 2011
How to delete a missed call
Press the phone button. at the top of the screen select logs. At the bottom of the phone press the menu key. select delete. select the entry you want to delete and press the delete button upper right of phone.
Mar 02, 2015 | Samsung Galaxy Cell Phones
Tip
Samsung Galaxy Core Pattern Unlock
Unlock Pattern in Samsung Galaxy Core 2 (SM-G355H)
Check how to remove it.
Steps:-
1- Charge your phone.
2- Switch off the Mobile.
3- Now, Press and Hold Volume up + Power + Home button.
4- When it enter Recovery mode, release the key.
5- Now Select Wipe Data/ Factory reset using Volume down and select it through pressing power key.
6- Select Yes- delete all user data and press power key to select.
7- Now, Mobile is getting hard reset and will be free from Pattern lock.
on Mar 15, 2015 | Samsung Galaxy Core LTE
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
I use Samsung R 248. Recently my dvd drive is not working. It can't read any cd or dvd. what should I do?
Try to delete the upper and lower filters in the registry.
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned.
Apart from this, make sure that the driver is enabled.
Thank you!
Feb 22, 2011 | Samsung Computers & Internet
Hello I have Samsung SH-S223 and it doesn't read any of CDs or DVDs My computer recognize DVD-ROM and everything seems to be good maybe I need drivers for it? But all drivers have a letter after S223....
Do you have itunes installed?
If so Itunes put upper and lower filters in the registry key taking control of the dvd.
Goto Start type in cmd if it is vista, if it is XP click on run, then type in cmd, then regedit goto these keys in registry.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
Goto each key listed above and delete upper and lower filters then close out of registry editor goto device manager go down to dvd/cd rom drives right click on the dvd drive and delete it and if asked to delete drivers for this device check box to delete drivers then close out of device manager and restart the computer.
These upper and lower filters will say something like Gear Aspi.
Nov 14, 2010 | Samsung Computers & Internet
Samsung sgh J700 mobile phone's right soft key,dial keyand delete key is not working. pl.help
The usual issue about keys not working is that you need to clean it inside out. You can bring to a certified technician to get it cleaned for you.
Cheers!!
Sep 04, 2010 | Samsung J700 Cellular Phone
I have brought gt-e1107 samsung mobile i want to change the setting from arabic to english language pls assist me
To change the setting from Arabic to English Samsung E-1107(By Criz Lalap)
0. Press * key for 2 seconds to unlock/ unlock the keypad
1. Press the upper left key( Go to Menu)
2. Navigate to lower right icon then press Ok( Go to Setting)
3. From the top navigate 3 steps downward then press ok(Phone)
4. Select the top list(Language) then press ok
5. Scroll left to right to find English language then press ok.
Jun 30, 2010 | Samsung Cell Phones
CAMERA IS NOT WORKING, IT SHOWS PLEASE WAIT REGULARLY, UNABLE TO LISTEN THE VOICE OF CALLER WHILE SLIDING OR ANYHOW. i think there must be problem in slider
Hi, simmipriya i think you have a problem of camera settings, firsstly you have to check that which storage device are you using for the storage of your photos, if these are saved in phone memory then change it to memory card, as j600 have only 17 Mb of memory space
1.Go to options
2.Click on serial 7 which is camera settings
3.After that click the upper arrow key or just go to default storage then click the right arrow key to change it to memory CARD then save it
i think this will resolve your problem
hope you will enjoy to continue with your mobiles camera
Mar 02, 2009 | Samsung SGH-J600 Cellular Phone
My password is not unlocking my t wing
you need to do a hard reset. this will reset the phone but it will also delete all memory
!- hold the two soft key(upper right and left key on keypad under screen)
2- while holding soft keys, insert stylus rset hole next to charging port on bottom of phone.
3. you will be given option screen to clear memory
Nov 04, 2008 | T-Mobile Wing™ Smartphone
Samsung slide lock
Yes that's possible with every phone just go on settings, security phone settings on automatic key-gard(keyboard) and turn it off. But before you need to know the code for locking and unlocking like in all nokia is green button and *.Not sure for samsung.
Jun 10, 2008 | Samsung SGH-D900 Cellular Phone
Samsung J700 Cellular Phone Logo
582 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
