Question about Kitchen Ranges
HI i have a bain marie and the lights keep
HI i have a bain marie which has 2 heat lamps and a 1500w element run by a simmerstat 6333.
the problem is with the lights, they keep tripping the circuit breaker, once the switch wire for the lights has been isolated the simmerstat runs the element fine and the breaker does not trip. how are the lights wired is there a ballast or something hiding behind the panel.
lee
dididsaythat
  • 291 Answers
SOURCE: Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Posted on Oct 14, 2007
fridgetech
  • 473 Answers
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Posted on Nov 12, 2007
hotuna
  • 288 Answers
SOURCE: solid cooktop elements not heating,tripping breaker switch in panel box,w&w/o cartridges
By cartriges do you mean the sockets that the element plug into? If so when one of these burn out it will cause these type of problems.
Posted on Jan 15, 2008
  • 156 Answers
SOURCE: sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Posted on Mar 19, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
When I pour water through it doesn't come out hot--unit doesn't seem to be heating the water
First check the hi-limit thermostat (90percent of the time this is the problem)...If that is the problem the part number is 2T-47499. Next check the Element for continuity with an ohm meter, if it is bad you will need to order a new one. Be sure to check the wattage, Some of the 120v brewers have a 1500w element and some have an 1800w element . Either can be used on the 120v machine. The 1800 watt element is a bit faster in heating. If you have the 220/240v machine you will have to order a "coil" shaped element. That is a 3500w element. There is a third problem possible and that is the Thermostat. The capilary tube could be broken (happens in the lime/rust/sulpher belt of the midwest)..If you know how to use an ohm meter you can find the problem quickly. I have a video on checking a Bunnomatic temperature, heater and hi-limit circuit, maybe it will help. https://www.youtube.com/watch?v=tNVZkYPaZko
There is a page with all the parts you might need. Here it is.http://www.pamasco.com/bloomfieldthermostatsheatingelementsetc.aspx?page=2
Mar 02, 2016 | Bloomfield 8571 Coffee Maker
Broil element for siemens electric range
Order it through Amazon.com. They have EVERYTHING for it all. Type Amazon.com in and when there type in you what you need for what product you have. Garanteed you'll get an answer.
Oct 15, 2014 | Siemens Range 1500w Heating Element...
In bain marie no output from relay
You can use the 40amp....remember the relay can handle up to 40amps. This is controlled by a fuse that is installed in the device.
Dec 24, 2013 | Hatco Food Rethermalizer/Bain-Marie Heater...
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
Stove elements gets way overheated is it just the elements that need changing or is it wiring?
Hi - the elements are ok - theres no need for that to be replaced - the simmerstat or as some retailers refer to as regulator needs to be replaced instead - **MUST GET A CERTIFIED -REGISTERED** to do this - consequences could be fatal.
Jul 18, 2011 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
New heaters need to do a start up or testing for proper operation model f2f5103n TPI corp. Industrial type heater
When you are ready to test run the unit you should take an amperage draw reading on the elements.
The formula to see if the elements are drawing the correct amps is: (voltage x amps=watts) example: If a heating element is 1500 watts and your voltage is 120 volts, then your amps will be 12.5 amps. (120v x 12.5A=1500W)
The easiest way to check amp draw is with a clamp on amp meter.
Nov 24, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Wiring of a bain marie
How do i wire up a bain marie with L1,L2,L3 and neutral and earth,do i have to send a live wire to all 3 lives ?? Thanks
Mar 02, 2008 | Ovens
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
