Question about Visioneer OneTouch 9220 USB Color Scanner
Visioneer 9220 scans red
I have tried everything the Visioneer site has suggested. I have removed, uninstalled and re-installed til I could scream. Everything I scan has a red haze to it. The scanner is only about three years old and not used excessively. Can it be fixed or should I buy another one?
Thanks
  • Anonymous Dec 08, 2008
    Same thing. Moved the location, but the cord is still the same. How do I replace a bulb in this thing? Or is the unit then shot?
    Sergeant:
  • 291 Answers
The scanner bulb is getting to hot. Check power adapter voltage output or replace if is getting to hot
Posted on Nov 22, 2008
Lost the software for visioneer onetouch 9220 usb scanner
You can go to visioneer's website and find that driver here: http://support.visioneer.com/products/9220/downloads.asp
For future references, simply take the manufacturer, the model and type download driver at the end of it, and place in Google Search. Then, MAKE SURE the link you follow starts with the manufacturer's website. Best of luck! Hope this helps...
Aug 24, 2014 | Visioneer OneTouch 9220 USB Flatbed...
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
Will this Visioneer 4400 scanner driver work on Windows 7?
Currently there is no driver available for win 7.But one of my friends had the same issue and he
fixed it by asking windows to automatically find the driver from internet and it worked for him.So I suggest you try the same,this is what you need to do
1) First go to control panel,then open Program and Features.
2) Uninstall any driver for the Visioneer 4400 scanner that you have previously installed and reboot the computer,if there is no driver installed then skip this step.
3) Make sure your scanner is connected to the computer,now right click on "My Computer" and click "Manage"
4) Now choose "Device Manager" from the left panel and it should list all the devices on your computer on the right side.
5) Now select the option "Scan for Hardware changes" from "Action" menu on the same window,you can also do this by right clicking on any of the device name in the list (ex,drivers,keyboard) and choose "Scan for Hardware Changes"
6)A new category named "Imaging Devices" should appear on the device list now and when you expand it by clicking on the arrow, it should show your scanner as "42 Bit USB Scanner"
7)Now right click on "42 Bit USB Scanner" and select "Update Driver Software".
8) Now choose the first option,"Scan Automatically for updated driver Software" and Windows
should automatically find a working driver and install it.Now your scanner should work.
Let me know if it helped,good luck!
Nov 30, 2010 | Visioneer 4400 Flatbed Scanner
I am unable to scan in Onetouch 9220 after I unlock the button.
Look for the fiber strip along the bottom of the scanner inside the glass. Clean it and the mirror-like thing on the carriage above it. These things work together to encode and decode. Dirt drives them nuts.
May 24, 2010 | Visioneer OneTouch 9220 USB Color Scanner
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Scanner says it is lock, but it isn't
I had the same problem. The scanner car is stuck on the travel rail. Disconnect the scanner and remove the top. Turn over and remove 4 screws holding top to bopttom body. Turn right side up and push in very hard on the lower riight side of body to release snap in holding top to bottom. There are four snaps, one at each corner of scanner. Do the two rear snaps next. Then the left front should slip off. Unfold top toward front so as not to pull butoon wires out of track in bottom body. Clean 1/4" rail at rear of scanner and apply small amount of vaseline. Move car by turning gears at left rear to get to all of the rail. Reassemble. Happy scanning.
Jan 15, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Vista functionality/drivers
Sorry, there are NO Visioneer drivers available for your scanner. Unfortunately, that model was one too soon for them to develop the drivers since it's been discontinued a while back.
However, within Vista Support, there are ways to install the scanner and while you may lose some functionality, you should be able to scan, at the very least, pictures -- IF Vista has 'generic' Visioneer-type drivers within it database. (Meaning, when you plugged it in to the computer and turned it on, did it find the scanner, but not the EXACT model? If it found A scanner, I'd let it install those drivers to see if you can get it to scan, etc. through the Photo Gallery, etc.)
IF you're successful with Vista recognizing the scanner, you would go through Vista's Window's Photo Gallery and/or Window's Fax and Scan -- as well as downloading 3rd party OCR software (like AbbyReader) and/or TWAIN drivers that are compatible (another whole level of "technical"!)
If none of the above works you may want to replace the scanner with one that's supported.
Good Luck!
Maggie B
Feb 25, 2008 | Visioneer OneTouch 9220 USB Color Scanner
Red image
the problem could be the cabling between the scanner and the Computer itself.
Other than that the lamp is possibly faulty or on the way out.
try uninstalling and re-installing the scanner.
Also check that the AC adaptor is,nt overheating, unplug for an hour and then retry setting it up.
Mike @ Compurepair.
Feb 22, 2008 | Visioneer OneTouch 9220 USB Color Scanner
My scanner does not scan properly
time for a new scanner. these are cheap units and sounds like your lamp is going.
Jan 13, 2008 | Visioneer OneTouch 9220 USB Color Scanner
131 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
