Anonymous Posted on Jun 01, 2010
C 2000 error code
After replacing the gear motor fusion machine went into code. C 2000
Anonymous
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Jun 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
91
Questions
Helped
24282
Points
199
Go back and see what you did.un plug all the plug and plug it back in.make sure all the plug is in there right place and you did not skip a plugy.i can asure you its something small
How to setting E02-02 code panasonic photocopier machine
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
Good day how do i solve error C2500 Kyocera 4035
http://www.copytechnet.com/forums/kyocera-mita-copystar/20557-kyocera-km-4035-system-error-c2500.html
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=KM4035&code=C2500
Kyocera KM4035 Error Codes
Exploded Views and Parts List Free!
Code
C2500
Description
Paper feed motor problem • LOCK ALM signal remains high for 1 s, 1 s after the paper feed motor has turned on.
Causes
Poor contact in the paper feed motor connector terminals. Defective paper feed motor rotation control circuit. Defective drive transmission system.
Remedy
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper feed motor. Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace if any.
2010 ford fusion hyprid power steering went out
Power Steering - Hybrid The electric power assist steering system consists of:
  • power steering control module
  • electric motor
  • torque sensor
  • rack-and-pinion steering gear
The electric power steering system provides power steering assist to the driver by replacing the conventional hydraulic valve system with an electric motor coupled to the steering gear. The motor is controlled by an electronic control unit that senses the steering effort through the use of a torque sensor mounted between the steering column shaft and the steering gear. Steering assist is provided in proportion to the steering input effort and vehicle speed.
your best bet would be to have the ford dealer check it out !
2answers
Error code sc500
Main motor lock up could be the photoconductor unit or main motor or gear that runs off of it
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
I'm getting the error message LE which says motor overload. I've read some comments on line that people have drained the water unplugged the machine for a couple of hours and the error message went away...
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thanks
2helpful
C-OF34 error code?
this error code means there is a low toner to developer ratio in the yellow developer the common causes for this problem is the pwb-mc board needs to be replaced or the yellow toner motor needs to be replaced or or the toner motor one-way gear has failed to reset the error code leave the machine on and open then close the front door if the error code comes back check and or replaced parts listed above.
24helpful
3answers
RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
k24674
ADMIN Andrew
ADMIN Andrew
