Question about HP Pavilion vp15 Monitor
Please tell me about monitor going to sleep - HP Pavilion vp15 Monitor
  • 11,361 Answers
The monitor goes into standby mode if it does not see the video signal from the PC or there are problem inside the monitor. Try it with other PC first, also check the pins on the VGA cable. If it still does not work, you will have to open it up. First place to check will be th caps (leaking/bulging top) in the power supply first, for this 2001 model year, I will not be surprised if it has bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
After going off line then want to go back in 1 hour, it tells that monitor is going to sleep, how can I prevent this
To prevent your monitor from going to sleep you will need to...
Go into your Contol Panel...select Power Options or Battery Settings....Click on Battery Power Saving Options....selcet...Never...under put to sleep.
You will have to start Logging Off at the Start Button.
Kind Regards!
Sep 23, 2011 | HP Pavilion F1703 17" LCD Monitor
Pleas tell me why when i open my monitor after one to two secound messeg tell me monitor go to sleep? pleas tell me the solution thank you
It can be caused by many parts of the monitor circuits.
Please read my guide and look at the albums.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
May 16, 2010 | HP Q1859 18 inch Monitor
My hp w2207 keeps going to sleep about every 30 misn or so while i am watching movies on it how do i stop this issue?
It is probably going to sleep because it's not getting any keyboard input.
You'll need to go to the control panel and the power options and tell it not to go to sleep or at least increase the time that it will remain idle before going to sleep.
Watching movies is not input, so it thinks you are not using it.
Nov 16, 2009 | HP w1907 LCD Monitor
My computer says its our of range to adjust settings.
right click on the desktop click on screen setup and click on sleep mode add 20 minutes to it, then right click on the desk top and go to properties choose 32 bit and 900 dpi and click ok see if that's better if it is click ok, need more info or that does not work just re-post a comment and I will get back to you..
Jun 26, 2009 | Sony SDM-HS73P 17" LCD Monitor
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
Monitor TFT 5015 now says "going to sleep
Make sure the laptop's external VGA port is turned on. There will be a function key somewhere on the keyboard (location varies by manufacturer and model) that controls the connector. If the connector has gotten turned off the external monitor will go to sleep because it's not getting any input.
Apr 09, 2009 | Compaq TFT5015 15" LCD Monitor
Monitor going to sleep
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Cheers.
Z
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
Click start...control panel...power options...set monitor to never turn off.
Also, you may have a bad backlight bulb.
Oct 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion vp15 Monitor Logo
114 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
