Question about Vacuums
I need a replacement small juicer cone for my Breville JC7 'Squeezed' juicer. Narelle Jensen 0418 153651 jan.jensen@bigpond.com
  • 1,284 Answers
Hi, you have to contact Breville Care on 1300 139 798, 0800 273 845 to make a request for the part and you will be directed to the nearest Breville outlet in your area..
Take care
Posted on Jun 01, 2010
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Remove hose adaptor for eureka maxima to replace with new one
We banged on the black rubbery part that holds the hard plastic adapter in place until the old adapter was broken into pieces then removed the pieces. The new adapter just simply snapped into the rubbery black connector piece. I then used a screw driver to scrape the gasket out of the old adapter and put it into the new one.
Dec 23, 2011 | Electrolux Eureka Upright Vac Maxima...
Instruction book for breville sandwich toaster SG18 required
Try this site. They have alot of small appliance manuals that you can download.
http://homeappliance.manualsonline.com/manuals/device
Jul 09, 2011 | Vacuums
I understand i can get afree download for a manual crazy scoops breville?
Breville is an Australian company as far as I can work out, their e-mail address is askus@breville.com.au.
Here is the PDF link. Right click on it and choose "Save As" then choose where o save it on your PC.
http://www.breville.com.au/media/mediaappearance/11590/BIS200_IB_0108_FA.pdf
Jun 14, 2011 | Vacuums
Need to find new heater bar for a game saver turbo
You can try the customer support number:
877-777-8042
FoodSaver's customer support website:
http://www.foodsaver.com/Support.aspx?id=sfaq&fgid=21
If you get nowhere with this, you could check to see if a thermal protection fuse is blown. Most electrical appliances that involve heat have a small thermal fuse that can be purchased at most Radio Shack stores. It's a small thing, about 1/2" long, with a cone-shaped end and wires coming from each end.
I hope you can fix this. Good luck.
Feb 17, 2011 | Vacuums
My filterqueen majestic is 10yrs old and just started to spark and smell of burning ive took it apart
If you have a burning smell from the motor, your motor is shot. You should be able to buy anew AMTEK Lamb motor for about $85-110 US. Request a double ball bearing motor as it will have a longer life span.
Also buy a fresh internal filter kit. There will be a small 5 .5 inch filter disc inside the cone protecting the motor in the event that the cone tears. Replace it .Also save and reinstall the small insulating disc that sits between the top of your motor and the screen at the top of the vac. This is to prevent electric shock. This disc is the size of a coin.
Post back if you need more help. Wiring is very easy. Do NOT twist your wires before installing into the connectors, twist the connectors, then tape to be certain they are on tight.
Nov 04, 2009 | Filter Queen Majestic Canister Vacuum
Brushes won't spin
The brushes are turned by belt and/or motor.
Mar 09, 2009 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
