Question about Toshiba e-Studio 45 Black and White Copier
Error c01 toshiba copier
Cant get copies just jam paper then error c01
  • 328 Answers
Main motor problem or abnormal
Posted on Jun 01, 2010
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
Paper jam error
Hi...
Check you copier if there is a paper hang on inside, remove the paper try and look for tha paper which is jam. And turn your copier on try to copy if itis ok.
Regards
PCmania
Aug 22, 2009 | Toshiba e-Studio 205 Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
E065 error
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Jan 15, 2008 | Canon NP 6035 Copier
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Toshiba e-Studio 45 Black and White Copier Logo
256 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
