Question about Epson Stylus Photo R300 InkJet Printer
General error or communication error - Epson Stylus Photo R300 InkJet Printer
  • 8,404 Answers
Delete the printer and reinstall ...
Posted on Jun 01, 2010
Error f01, what means?
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced
Jan 05, 2016 | Washing Machines
What is communication error 20 mean ?
The Comm. Error message may appear if the machine experienced a communication error while sending or receiving a message. This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line. In your case, it lost connection to the host / server. You just need to keep retrying or check the settings on the phone and confirm with the vendor if they have changed some settings on their end...such as PORT #, etc...
Sep 02, 2015 | Computers & Internet
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Getting an U99 error with a panasonic DMR-ez48v vhs/dvd combo unit. Any idea what this indicates
The U99 error is a "general communications problem". Were you trying to switch sources when you were recording? You shouldn't to avoid this error. That's what we did with my Uncles unit.
Mar 01, 2011 | Panasonic Televison & Video
Error comm 0001
Generally this error(Error 0001) is observed while receiving Fax. The Error Code arises when sender not using G3 Fax Machine.So it is a communication error.
I think it helps. Let me know.
Best Regards Fixya Expert Chandrashekhar Bhat
Dec 16, 2010 | Canon FAX L-120 Plain Paper Laser
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
General error on Mobile Aim
1. Go to sign in screen on aim.
2. Go to options.
3. Click down to preferences.
4. Click reset application at bottom.
Jul 06, 2009 | Verizon Communications enV2 Cellular Phone
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Epson Stylus Photo R300 InkJet Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
