Question about Compaq Presario CQ60-220US PC Laptop
I need to enable the wireless function of a compaq cq60 laptop and it appears I should be using a function key in conjunction with the wi-fi switch itself to activate. Could anyone help? Which function key do I need to use? Thank you.
    President:
  • 627 Answers
Press FN+F8
Posted on Jun 01, 2010
  • fish4000 Jul 24, 2011
    1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Wifi button location
To enable Wi-Fi you may try following the below steps:
    (1)Turn on the computer.
    (2)Keep tapping the F2 key at the startup, BIOS screen appears.
    (3)Move to wireless tab.
    (4)Select Internal Wi-Fi and enable it
    (5)Now move to wireless hotkey and select Wi-Fi & BT.
    (6)Save this settings and boot to windows.
    (7)Now press FN key+ F2 key to enable Wi-Fi.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 16, 2014 | Dell Precision M90 Notebook
Hp nc6120 wi-fi problem
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 06, 2012 | HP Compaq nc6120 Notebook
Wireless on my compaq c60 is disabled but i cant find a switch to enable it. Can i use function keys and if so which?
I am unable to find a photo of your laptop's keyboard, so I cannot be certain which function key will enable your wireless adapter.
However, most laptops are very similar, so this solution should work for your problem.
1) Locate the secondary function key (probably labeled "FN") on your keyboard.
2) Locate the key which controls your wireless adapter as a secondary function. It will have the following image on the key: http://cdnsupport.gateway.com/s/Mobile/2007/Phantom/WirelessIcon.gif
3) While holding the FN key, press the wireless key
4) Your wireless adapter is now enabled. If you are still having wireless issues, the problem was not that the hardware wireless adapter was disabled.
Apr 07, 2011 | Compaq Presario CQ60-212US Notebook
Where is the key to turn on wireless on the Compaq Presario CQ60
The Wi-Fi button is explain fully on PAGE 2-3.
It's a button on the base (center) /////right of the power button.
Link HERE for the full manual of Compaq Presario CQ60.
Please keep this link for reference.
You will need to be near a wireless access point to gain signal to the internet.
Example: Starbucks coffee shop or library.
Please follow the direction on your operating system on how to gain access to the internet.
Jan 31, 2011 | Compaq Presario Notebook
Compaq Evo N610c Wireless Problem!
FN+F2 is given to disable and enable the wi-fi means once you will press it the wifi will turn on and in second attempt it will turn off.
Check in device manager whether it is showing any wireless ethernet controllerand if not then install.
Thanks.
Dec 09, 2009 | HP Compaq Evo Notebook N610c
Cant turn on wireless capability
Press the Fn Key and then while holding it down press F1 key. There will be a pop up box come on screen, click wifi enable and ok.
Its that easy.
Sep 02, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Wi fi
Could you make sure that wifi switch is turned on.
This will be physicall button on the laptop of function keys combination that enables wifi.
If wifi switch is on you should be able to see wifi networks in range. IF you see networks but can not connect this will be network security issue. MAke sure that wireless network router is properly setup and security key you enter is correct
Jun 08, 2009 | Compaq Presario 700 470024-192 Notebook
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Wireless is not working
what is your Windows OS? XP or Vista? to activate the wireless, press Fn F2 or just look for the wi-fi switch located above the Function keys or sometimes on the edge of the laptop with a picture of wireless signal or wave or antenna that resembles wireless.
Aug 01, 2008 | HP Compaq nx6110 PC Laptop
Compaq Presario CQ60-220US PC Laptop Logo
985 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
