Question about Maytag MDE9700AYM Electric Dryer
A kerthumping noise with every rev.When rotated manually by hand
In reverse,a grinding noise is heard
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgjfg
Posted on Sep 30, 2010
Machine fills, then on entering wash cycle makes loud grinding noise kinda like a dull hacksaw on rusty metal.
Does it make the sound when you turn the drum by hand? It could well be the drum bearings that have gone.
Aug 01, 2016 | Washing Machines
Noise coming from one wheel - sort of a grinding noise but not consistemt
Can be three things
worn wheel bearings
stone in the brakes (most likely)
worn or incorrectly fitted pads
Jack the car up, spin and look.
Jul 10, 2016 | 2004 Hyundai Santa Fe
Grinding noise in reverse
check mud flaps on wheel arches in case bent and rubbing on tyres
Aug 31, 2015 | 2008 Kia Sportage 2.7
Wheel bearing
If grinding noise is heard coming from front side, lift up both the front wheels and rotate the wheels one by one to listen to the sound, if any. If a noise is heard, replace the front wheel bearings as a set.
If the front wheels do not produce any abnormal noise when rotated, lift down the front vehicle. Lock the front wheels with blocks, release the hand brake. lift up the rear wheels and try to listen to the abnormal noise. If the noise is heard, replace the differential bearings and seals. Top up the differential oil to the mark.
Dec 12, 2013 | 1998 Toyota Tacoma
What is it when in reverse the automatic transmission on a 1999 Camaro grinds?
Reverse is not "synchronized" forward gears are, so it does make some noise, try shifting to 2nd before engaging reverse to slow gear rotation and limit gear clash or grind.
Oct 08, 2012 | 1999 Chevrolet Camaro
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
2001 2wd, v6 tracker LT, 110K miles; Grinding, clunking nosie
If it sounds like a rumble from back wheels it may be the rear end going out. Mine has been replaced twice with used rear end. You should be able to confirm it by looking at the rear tires both sides of tire for an oil leak or wet spot on tire or rim.
Mar 29, 2009 | 2001 Chevrolet Tracker
2002 Mitsubishi Montero Sport XLS transfer case issue.
The best place for a DIY manual is www.ALLDATADIY.com their info is very accurate.
Jan 29, 2009 | 2001 Mitsubishi Montero Sport 4WD
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MDE9700AYM Electric Dryer Logo
140 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
