Question about Epson Expression 1680 Professional Flatbed Scanner
Transparency adaptor won't close
Almost overnight my Epson Expression 1680 Transparency adaptor wouldn't close properly, leaving a gap of about 2" open. I used some w-d 40 in the hinges because they seemed stiff. No help. I was able to continue to use it, but now It has gotten so serious that I now get error messages when I try to scan "Close the Transparency Adaptor"
Opening it wide,I looked at the back end where the top is screwed onto the bottom. The right hand side of the metal bracket is actually bent, just to the right of the 2 large screw type sets (there are two pairs of screws). This is because of the times i pressed down trying to make it close.
I am guessing that something internal has come undone, knocking the unit out of alignment.
Any suggestions? Has this ever been described before?
  • 2 more comments
  • Anonymous Oct 16, 2008
    Transparency adaptor won't close and leaves a 2 inch gap. How to repair this problem.
  • Anonymous Nov 06, 2008
    I have the same problem. Very frustrating, also tried the WD40.
  • Anonymous Nov 11, 2008
    i have the exact same problem.
  • anitagil Jan 11, 2009
    I have the same problem with the 1600. Actually, it is now stuck in the completely open position! As it seems to be a problem with the hinge unit, I am going to contact Epson to see about getting a new hinge unit.
    Thanks for posting!
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Posted on Aug 21, 2009
I have the model Epson expression 1600 which is similar. Remove the transparency adaptor from the scanner remove the six screws that hold the bottom glass and plastic half of the unit. I used a bit of silicon based grease on all the surfaces that slide in the hinge mechanism. Note the micro switch on the right side of the hinge. It has to be depressed when the lid closes or the scanner thinks the lid is open. Over time the hinge mechanism gets slightly bent and it wont trip the switch. My solution was to just tape the switch closed. You may come up with a more elegant solution but the switch is the problem. Reassemble and your scanner should work with transparencies without the error message
Posted on Dec 29, 2008
2 Suggested Answers
SOURCE: Expression 1680 Professional Flatbed Scanner: Transparency adaptor stuck in open position. The h...
Had the same problem. By lid I assume you mean transparency unit. To fix, it is necessary to remove the transparency unit from the scanner. Then IN A CLEAN AREA! with the glass side up unscrew the 6?screws that hold the top unit together. There will be a hinge assembly inside. You must remove it, clean it, and re grease it thoroughly. I used lithium grease from an aerosol can. Has not given me problem since. the whole process took about a half hour. just make sure you are gentle, and keep everything clean.
Posted on Dec 11, 2010
I have an Epson expression 1680 with the latest drivers and a usb hook-up to my Windows 7 computer. I can scan, the computer recognizes everything but I cannot get it to work to copy film...it won't let me...
Hi, most if not all scanners don't work when you try to use it on film. Usually, the only way for you to scan film or transparencies is you have to buy an accessory for the scanner called a "transparency unit" which does not come installed with your scanner when you buy it. Unless your scanner says that it came with that accessory then you won't be able to scan films or transparencies at all.
Feb 05, 2018 | Epson Expression1680 Professional Desktop...
May 05, 2010 | Epson Expression 1680 Professional Flatbed...
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
Lid will not close and is very difficult to put down
Feb 18, 2010 | Epson Expression 1680 Professional Flatbed...
SORRY MAY BE A BLONDE QUESTION
well now there's something i've never tried.... i would suppose you can but they will likely turn out like... well negatives
Robert
Feb 17, 2009 | Epson Expression 1680 Flatbed Scanner
Door/Hinge is very tight, have to push down hard when scanning
Remove the transparency unit from the scanner. Then carefully remove the six screws holding the hinge. Use WD 40 to lubricate hinge.
Jan 13, 2009 | Epson Expression 1680 Professional Flatbed...
Lines through negative scans
Clean the glass surface with Iso propyl alcohol (Industrial grade is enough). Dont use any solvent. Just for immediate usage, you can use your aftershave and clean. Clen with a soft cloth.
S. Mohan, Chennai. India
Nov 28, 2008 | Epson Expression 1680 Professional Flatbed...
Scanner won't turn on
Try to test the power cord of the scanner (cable from scanner to outlet) using multitester if there is an electricity or if you have extra power cord test it. Maybe that's the defect. If that's not the problem it is now the scanner itself, have it for the repair man or technician.
Thanks
Nov 19, 2008 | Epson Expression 10000XL Flatbed Scanner
Hi-
Do you have any existing drivers for new epson scanners( models), if you have then there are compatibility issues between new drivers and old drivers, are you using a leopard 10.5 operating system or tiger 10.4.**? try uninstalling every epson info from applications folder and from library/image capture and library/preferences. you an use the finder to search for epson scan and drg them all to trash. Try using image capture application as well if it will scan when you run it, then reinstall driver.
One more thing, when you click on epson scan, does it bounce continouosly from the dock? if it is then look for a subfolder and install everything in it.
Keep me posted, thanks!
Aug 27, 2008 | Epson Expression 1680 Flatbed Scanner
Epson Expression 1680 Professional Flatbed Scanner Logo
2,413 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
