Question about Canon Pixma iP4500 InkJet Printer
I have an iP4500 Canon and I have trouble with the ink
I kept using the Cyan and Magenta cartridges after getting a message that they were running out, because I was waiting for an order to arrive. When I finally replaced them the new ink wouldn't seem to flow through. I deep cleaned the print heads and checked that all the tabs were off the cartridges. The ink still won't come through. The same thing happened with my previous Canon printer and I resorted to buying a new one. Is there anything I can do to get the ink flowing?
    President:
  • 1,138 Answers
Hi!
There are different possible and safe ways to clear the clog in your cartridges..
The basic steps is to clear the clog using the printers software utility that is installed in your computer...how? on your control panel..double click printers and faxes, when your printer icon appear.. right click on it and click properties to bring up the utility..on the maintenance service tab...press the button for cleaning the cartridge.
the second thing to do is flushing the printhead of the cartridge directly from the tap water ....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
The last thing to do and it will take you sometime is to soak the printhead portion of your cartridge in a mixture of ammonia and hot distilled water, (please make sure that the contact point of the cartridge to the printer is not soak).. Place the printhead on the hot water and leave it there for about 4 to 5 hours..move it on different location from time to time..After soaking, rinse it with distilled water and dry it with cloth...
After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
Try printing a test page and see the outcome...
If you find this information very helpful, would you be kind to rate this solution and vote below.. thanks..
Posted on Jun 01, 2010
Testimonial: "Flushing out the print-head worked brilliantly. Thank you for this advice, it has saved me a lot of money!"
Can you put a non photo ink cartridge in a photo cartridge location
Use a syringe pull the ink out of the full cartridge and refill the empty one
Jul 24, 2014 | Canon Cyan Printer Ink Cartridge For Pixma...
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
I have a iP4500 and it won't print the magenta. I
You need to try another cartridge before anything else, some generic carts. don't fit right in the printhead, the ink pad is too far up inside the cartridge. You may have a defective printhead, or possibly the purge unit is not cleaning properly. I can't tell without seeing the printer.
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
Canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Dec 10, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
618 people viewed this question
old marine
old marine
