Question about IBM ThinkPad X31 2672 Notebook
What is the fastest 32GB CF card [UDMA presumably] that I can use with an X31 2672 2GB XP 160GB HDD?
  • IBM Master
  • 4,924 Answers
Posted on Jun 01, 2010
Testimonial: "Yes because it included test data on both tranfers to cameras and computers. Thx"
Dear sir I have a HDD 20 GB fireball and I have problem with it in the low speed of read and write in operation. I instaled windows XP and I want to improve speed my HDD. please advice me about this...
Its a very old hard disk, few things you can do,
1.. Get into your pc's bios and see if 32bit access is enabled for your disk, if not enable it, reboot.
2.. Goto control panel > device manager , double click on your IDE controller and check had disk status, if is on PIO mode or UDMA , must be at UDMA. Set it if not.
Jul 29, 2011 | Quantum Fireball Lct20 (QML20000LD-A) 20...
CONSTANT FLASHING CF LAMP NIKON D300
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Nikon D40X Digital SLR Camera Digital...
Sandisk card is not registering when attached to the computer
Make sure the reader is not USB 1.0 because the 4GB CF card is a UDMA type card that the USB 1.0 cannot recognize. Upgrade to a USB 2.0 reader and you should have no problem.
Apr 09, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Turn on and a message says no card even with card installed
The camera may not be able to accept the newer cards like the CF UDMA or the SDHC. Since there is no model listed you will have to look up your camera brand and model specifications. If the camera is not UDMA or SDHC compliant then that is the problem. Otherwise that may be a bad card, check it to see that another camera and computer can read it. If yes, then it is something more in the camera.
Feb 28, 2010 | Cameras
I get an Err CR inmy Canon EOS Rebet XT-Bad card?
  1. Test the CF card on your computer or another camera. If it works fine then it may not be the card. Make sure the card is not UDMA, 4GB or more in memory size since those new big cards are not compatible with the older cameras.
  2. Look inside the CF port. Make sure that none of the contacts that connect the camera and CF card are bend of smashed flat. If so then the camera will have to be send off for repair. This is a rather expensive repair, $250 is not uncommon.
  3. I it is neither of these then take the camera to a local camera shop and ask them to look at it. It may need to be sent off, but testing another brand card, or resetting the camera or checking for physical defects couldn't hurt at this point.
Nov 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Pictures on card (can see on computer) but not on frame
Make sure the memory card is not UDMA if a compact flash memory card or SDHC if an SD memory card. Neither of those are going to be compatible. You will need smaller cards like 1gb SD or CF variety.
Sep 22, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Lexar udma cf card reader not responding
remove and reinstall driver, since no OS mentioned hard too help. see if recognized in the ''my computer'' section.
Jun 22, 2008 | Computers & Internet
EMACHINE T1840 160GB HDD UPGRADE
The Safest thing to do is to actually create a 2nd partition
which will give you the full use of the 160gb
remember thou that windows sees a K as 1024
not the 1000 measurement you would expect
On older pcs there is a limitaion 137 then when formated bringing it down to 127gb
If me I would run the Maxtor setup and choose custom ,delete the partition already made, then create 2 partitions ,then tell it to copy from your old c:\ to the first partition,making new hdd the new boot drive
another option is go buy a ATA133 PCI card with 48 bit addressing
Nov 14, 2007 | Computers & Internet
IBM ThinkPad X31 2672 Notebook Logo
130 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
