Question about Canon CLC 1140 Copier
Error E072 frequently error comes after transfer drum is move while initializing
  • 1,219 Answers
Change the transfer corona assy.
Posted on Jun 02, 2010
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
MI get an E072 at the atm, what could the problem be?
E072 refers to the cleaning drum motor transfer.
The transfer drum has a sensor on the inside that allows the internal mechanism turn initial position, from there to retention, transfer, separation and cleaning. This mechanism is easily positioned to the starting position from the service mode> FUNC, BRUSH, HP. If the problem persists, you have to remove the drum and check smooth transfer care to check their points of support to the main axis, sometimes is slowed by a rubber strip side to slip out of place becomes entangled in the shaft and causes this error.
I recommend you check this engine, in some occasions the main door switch when it flamed this problem also gives you disassemble and thoroughly clean your platinum.
May 05, 2011 | Canon CLC 1110 Copier
Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
May 06, 2009 | Canon CLC 1000 Color Copier
Canon CLC 1130 Code E 072 0202
faulty.
faulty.
Mar 12, 2009 | Canon CLC 1120 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Re: Canon 1140 E072 0002
change your transfer cleaning assy.
Aug 31, 2008 | Canon CLC 1140 Copier
Have an OKI Printing Solution C5800 color printer received the following error message: Check Toner cartridge 543K Toner Sensor error - have already changed the Drum and the toner. The error will not go...
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Aug 08, 2008 | OKI Office Equipment & Supplies
E072 error CLC 800
i need a sub code like e072-002 or 003 and so on because it can be several things generally it has to do with yopur transfer drum any where that macvhine is way outdaTED AND THERE ARE VERY FEW THAT CAN SOLVE YOUR PROBLEM
Jun 04, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1140 Copier Logo
old marine
old marine
