Question about Polaroid TDA-03211C 32 in. LCD HDTV
Need a code for sky hd remote for polaroid tv
    President:
  • 1,099 Answers
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Posted on Jun 01, 2010
NEW POLAROID TV LCD LE-60GD13H NEED CODE TO OPERATE MY SKY CONTROL
If you telephone Sky giving the the make and model they will give you the numbers
Mar 16, 2014 | Televison & Video
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
I need a code for a bush bpdp 42 hd 2 tv for my sky hd box
2577 worked for me for the Bpdp 42 hd bush tv
Jan 07, 2012 | Televison & Video
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
Code problem
I got a tip for this and in this tip are codes you can TRY, now the sky universal remotes are senstive to tv codes so you need to try the manufacture codes if that does not work then you need to ditch the sky remote and get a remote that works with the sky box and the tv as a solution. IN my tip there are remote solutions as well, please do not shoot the messenger I am not sky or the manufacture I am just helping for free,
http://www.fixya.com/support/r4873816-universal_remotes_remote_codes
Jun 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Polaroid tlu01911cu remote code
I have one like this and found out its code is 0486 as a TV on a Silvercrest programmable remote
Jan 04, 2009 | Polaroid 1720-7 Remote Control
Sky remote do not work wit polaroid tv 3232
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Polaroid TV is 0765.
Hope this suggestion, helps you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Jul 12, 2008 | Polaroid FLM-3232 Television
Polaroid TDA-03211C 32 in. LCD HDTV Logo
320 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
