Question about Bosch KGU32124 Bottom Freezer Refrigerator
Hi i have a14 year old bosch fridge freezer fd7607 kku3201gb01 model. the fridge works fine but the freezer does not. all the lights on the control panel are working and the motor seems to be working. any sugestions please. j, h.
docjohn174
  • 943 Answers
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
Posted on Oct 06, 2008
  • 2920 Answers
SOURCE: bosch fridge freezer
i think you have a freon leak...that would tell you why its not getting cold and why its not working now at all.
Posted on Jan 28, 2009
  • 9 Answers
SOURCE: Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Posted on Mar 14, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
  • 19 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
could be an air leak around the door seals. put a piece of paper between the door and the freezer if it slides around easly then the seal is leaking air and moisture into the freezer. Also -20 is extream. you could turn the temp up by 10 or 15 degrees and it may solve the problem and so money!
Posted on Jul 26, 2009
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
PDS22SBRLSS Ge Profile bottom freezer
hi is the fan motor running in the freezer. is there frost built up on the freezer wall did you pull fridge from the wall and clean the coils by the compressor
Sep 29, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Bosch KGU32124 Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
